1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Date: 08/16/2018 08:54 am
Date: 09/15/2019 08:30 pm
Date: 07/21/2017 11:49 am
Date: 08/08/2017 01:44 pm
Date: 03/05/2017 03:27 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Mirror
Date: 04/15/2020 01:42 pm
  • Online today: 1,106
  • Guests: 124
  • Total: 124
Performance trick: Advancing the cam one tooth on the timing belt?????
Started by gaeliccouple, November 08, 2013, 02:49:34 PM
I haven't run one of these in a good while now but beware of the belt teeth, some have square cut teeth and some are rounded, you need to run the belt tooth that matches the sprocket. It may be an issue since around'98 or so they started making elastomer hypalon belts that last about twice as long (120K miles vs. 60K) as before but thinking they may not be correct tooth, CHECK IT. Thinking earlier models may be square, the later rounded. Someone correct me if otherwise. Thinking if one changed sprockets to match the later belt it would last much longer. I am not firm though on how long they made 2.3s or the later 2.0 Ranger motor.
I always ran Gates and never had any early fails but I changed religiously around 60K on stockers. If you run big cam/springs you may have to go more often than that.
If you have asymmetrical lobe timings that linked earlier post method will not work, it is really the backyard way anyway. Correct is to measure with dial indicator like 1 mm. or so into start of valve lift and then same at the end, figure the middle from it and your centerline number. Some cams use .040", some use .050" depending on the cam maker. Look at the cam card, always specified.
Ford retarded the cam on all of their V-8 back in the 70's. They did it with the crank sprocket. All you had to was change the sprocket with a late 60's or early 70's, and bingo!!!! That gutless wonder would now smoke the tires. Its so much harder to pass the smog laws now, their all doing it now day no doubt.
Henrius
Had a 2.0L Pinto that could never go up a steep hill except in first gear. We discovered that when the cam belt had been replaced, they set cam timing one notch off by accident. When we corrected this, I could go up any hill in 2nd gear!
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
Thanks, kinda figured it wouldn't be any different than any others, guess it's time to find absolute TDC and make up my own pointer, stock or performance don't matter cam should be degreed anyways.
Thanks old, that's the one. And yes, the pointer can be off so if you are installing a performance cam you need to find absolute TDC, use the spec sheet and a degree wheel. This is more for a stock engine and will get it pretty darn close. You can really feel the performance gain and most stock engines I have checked are retarded. You can even modify the stock pulley by filing the slot and making a shim. Believe me, it's worth the effort.
What brand of belts you guys use, is there any to stay away from?, and has anyone ever check the accuracy of the pointer on the outer cover?, I've seen quite a few(on other vehicles)that were off, of course the dampener can be off too the outer ring can/will move, I always mark them and check it anytime I set timing.
Quote from: 71pintoracer on November 09, 2013, 07:33:46 PM
Wow I really have been gone a long time.
Well, welcome back - we've missed you!  And, by the way, it was good to see you Wednesday morning... it had been a while!
Dwayne :)
Wow I really have been gone a long time. Picture of my car in my avatar is gone!  :(
Wow....haven't been here in a while but it's nice to see that old myth is still alive! However, if you start with a 4 degree retarded "emissions" cam and the head has ever been milled one tooth might be close hahaha! Really though, one of the most noticeable power gains you can do to a stock Pinto is to degree the cam. Most of the time they are retarded from the factory so even getting it "straight up" will make a big difference that you can actually feel. I posted a thread  with pics once on how to do it, it's pretty easy. Maybe someone can find it and put up a link. Or it could be gone, I couldn't find it.
Just now counted teeth on that sprocket and 9.5 degrees per tooth, or, too much. You generally never go more than 6 degrees or you got cam timed wrong. I have never seen an engine where you could move by a full tooth and have it run right much less optimum. Why jumping by one tooth will show up as errant running. Mechanic was wrong anyway, when you advance cam the rpm range DROPS not increases. You retard for more rpm.
You don't retard by a set number of degrees in a guess anyway, cam comes with a card that has you correct engine for true TDC then you put cam on mark suggested by grinder and then move away either way from that 'ideal' point. Generally in terms of lobe center, use intake lobe center since that is the most felt point when timing is changed. Intake can run from anywhere from 104 to 114 lobe center, the lower number would be for extreme like low rpm pull off turns dirt track to the high number being used for dead stock cam with low lift to still be able to pull out some top rpm with no lift. High-perf will close up to 106-110 depending on use. Some depends as well on lift and where exhaust cam is located, you cannot separate the two since on same cam. Not like twin cam stuff which is so much more adjustable.
I just received this adjustable cam pulley today from Evil-Bay. This is the right way to adjust the cam timing. This one pictured is for a 2.0L but there are also ones to fit the 2.3L. If you have access to a dyno, you can dial it in for max power.
I changed the belt in mine and I got one from the Zone(gotta be China junk)and it will not time straight up, it's either 4 advanced or 4 retarded, so I just left it at 4 advanced.
gaeliccouple
The only thing I can figure is that perhaps in the late 1970s and 1980s Ford engineers had to retard cam timing in order to detune the 2300cc to meet emission standards and that perhaps advancing the cam timing brings it closer to the ideal position for the sack of performance versus emissions. Just a theory!
slowride
You might start looking for another mechanic. Changing cam timing slightly moves the peak torque... advance the cam to slightly lower the peak torque, retard it, raise the peak (higher rpm). 1 tooth is too much advance for most any engine. Maybe if you milled your head alot and used the stock emissions retarded cam......
gaeliccouple
Performance trick: Advancing the cam shaft one tooth on the timing belt???
I was talking with my mechanic and he regaled me with a story of how he had a 1980s vintage Mustang with at 2300cc. He claimed he advanced the cam shaft one tooth on the timing belt and it yielded a significant increase in horsepower. He cautioned that by doing so the engine would now be able to rev to very high RPMs it was not designed for and that if the driver wasn't very mindful of the RPMs the engine would tear itself apart!
Have any of you actually done this or heard of it before? He suggested I try it with my Pinto. I think I will pass
