Date: 09/01/2017 11:58 am
Date: 09/10/2018 10:41 pm
TWM Intake
Date: 08/15/2018 08:20 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 02/22/2017 01:58 pm
1979 pinto
Date: 04/19/2018 02:02 am
Date: 09/22/2020 11:33 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 553
  • Guests: 235
  • Total: 235
turn signal help???
Started by Wedgezilla, November 07, 2013, 05:39:14 PM
Check your bulb sockets. Sometimes there is corrosion.  On the front lights, sometimes the terminals do not make a good contact so when you wiggle the wires they work.  The grounds in the front get corroded as well.  Lastly, it can be the switch behind the steering wheel.
Every Pinto I have owned has had one of those issues which caused the turn signals not to work or work properly.
Wedgezilla
my turn signal just stopped working :-[ i replace flasher unit all my running lights hazard lights head lights still work ihave only found one fuse box...it only has like 6 fuses in it its right above my right knee if im sitting in the drivers seat is this the only fuse box??? anyone have any ideas??
Darrin E Dant
