1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 08/13/2018 02:46 pm
SVO SWAP
Date: 03/15/2018 03:12 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 08/13/2021 10:39 am
TWM Intake
Date: 08/15/2018 08:20 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 02/28/2018 09:18 am
  • Online today: 563
  • Guests: 262
  • Total: 262
Uremco Carb
Started by From_Jonah, October 28, 2013, 08:37:01 PM
The '73 should still be one that is either all on or off, the metering ones were used in the early feedback cars, or the ones with electronic fuel control. You have to be careful with vacuum line setup if using a later metered power valve, if not careful you think you have PV operating but it's not. Better to have the earlier on/off one anyway.
Look at the valve and seat, immediately obvious which is which, the on/off one simply uncovers a hole, the other one does it gradually with a long tapered valve there. If running hi-perf stuff you could burn some pistons running the metered one. IIRC, the metered one does not have a metering jet lower down in the passage, by itself it is the jet. The on/off one there is a lower metering orifice down in the hole further, the hole closed on/off is NOT the restriction there.
gaeliccouple
I have a 1979 Pinto that had the same stock smog carb on it. I rebuilt the original carb and it still ran like shizod. In desperation I pulled a filthy old carb off a 1976 Pinto for $25. I cleaned it up and put it on. The car ran a world better!
I believe the earlier model years of the 2300 motor had better carbs because they did not have as much smog crap designed into it. The 1979-80 carbs are definitely different from the earlier years  of the 2300 motor and are at the high point of emission controls.
Just my experience.
rramjet
Quote from: amc49 on November 02, 2013, 03:16:53 PM
Last post brings to mind a question. Does anyone know where I can get the power valve rubber diaphragm for an early 5200 by itself? Looking for the one that is simply on and off rather than the one which meters fuel over a slope like the later ones do. All I really need is the rubber itself, saw this issue becoming a problem in the future and modified one diaphragm shaft I had to drill the top and tap for very small screw and washer, now I can fit rubber diaphragms from other carbs that have different shafts but use same rubber there. Thinking Ford makes both another 2 bbl. and one of the 1 bbl. uses it as well. Trying to find a supplier of the diaphragm without buying the whole stupid kit.
I'm interested in your Power Valve mod. I have a 73 2.0 with what I believe to be the original 5200 with a rebuild kit put in by PO. It has a slight surge at around 60 +MPH and I have wondered if the Power Valve diaphagram might be leaking, if they can do that. All I ever heard about them doing was blowing out with backfires. Would a 73 be one that meters or is it newer ones.?
Thanks
That was quick, part# PV889 at $8.99............................
I'll have to look them over..................
Have you tried this place, they sell a lot of individual parts?..
http://www.allcarbs.com/
jeremysdad
I would. New is always better than reman'd, no matter the car. Where are you located? You're an 80 model Pinto, so...emissions could be a factor. If so...idk what to tell you... The rebuild kit for my carb went up 250% from 2/12 to now (per Autozone's website, if they can even get it now...)
From_Jonah
I think I will go with a real weber. Plus the stock air cleaner is ugly as sin.
jeremysdad
Just get a real Weber, a K&N filter, and be done with it. (Your stock air filter could probably be made to work, but I always thought they were way too restrictive. Then again, I'm a 72 model, so I'm emissions exempt even in California. lol)
From_Jonah
Being from summit I would think that it would be a decent carb. I might give it a shot.
Don't see why it shouldn't work, I'm sure it comes with a warranty.
Any good rebuild should be fine with a little tuning
From_Jonah
