Wanted early pinto
Date: 10/03/2019 02:42 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 04/15/2017 05:14 pm
Date: 07/03/2025 04:35 pm
Date: 11/08/2020 02:10 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 09/26/2019 05:31 pm
Date: 06/05/2018 09:13 pm
  • Online today: 548
  • Guests: 318
  • Total: 318
Tailgate Lock/key cylinder for 73 Wagon
Started by mrmellowgold, October 25, 2013, 10:04:35 AM
My 73 sedan takes an oval trunk key but the square key fits every other lock. My other Pintos only use the square key to fit all locks.
May still be missing a small part in that set. I see two doorlocks with the actuating rocker arms, the tailgate also has some sort of end-of-cylinder rocker arm or close, it swings to hit the lever mentioned that pops door loose. Don't see one in that kit although I see retainer clips and other small parts. The rocker goes on end of cylinder just like the two door locks have one, thinking the rocker shaped different and has no hole in it. You would use existing other parts to hook up cylinder, may not have them or it, as the case may be. When tailgate cylinder was removed it came out with the rocker on it, why it's missing too.
dianne
Quote from: mrmellowgold on October 28, 2013, 09:51:30 AM
I dont mind if it dosnt match with the doors, though it would be really cool if it did. My main question is, is the trunk lock, hatchback lock, door lock, different than the tailgate lock for my WAGON? I do not see anything on ebay or online that confirms what will fit the WAGON tailgate.
The link I sent you was for a wagon with all the locks and ignition switch at like 70 bucks...
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
bbobcat75
NOT SURE BUT HAVE ONE IN A WAGON TAIL GATE!!
LET ME KNOW.
1975 mercury bobcat 2.8 auto
mrmellowgold
dianne
Now that's cheap even if you have a locksmith do the rekey :)
Vehicles:
bbobcat75
Mellow gold I have a 73 wagon with the lock cylinder but no key would sell lock cylinder for $5.00 plus shipping
dianne
Quote from: bbobcat75 on October 26, 2013, 08:46:56 PM
My 78 wagon uses same key for doors and ignition but different key for tail gàte!  My hatch Bach one key for all locks and ignition
Just my 2 cents
Funny, depends on the year and model I guess on the keys. Ford must have been trying to save the 10 cents when they made the 73 wagon LOL
Vehicles:
bbobcat75
Just my 2 cents
dianne
Quote from: dave1987 on October 25, 2013, 11:11:07 PM
Good point dianne, I forgot about that! DOH! Station wagon's have the same key all around. o.O
You should know, this one was yours first ;)  LOL
Vehicles:
dianne
Vehicles:
Hmm, every Pinto I have seen has a different key for the trunk/rear tailgate. Door and ignition are the same, stock key is square head. Trunk/lift gate is a different "mirrored" tooth (the step of the key goes to the opposite side of the ignition key style), and has a round head.
EDIT: Correction. Station wagon's have the same key all around. I've had my Sedan for way to long, it's starting to confuse me! DOH!
dianne
Sorry, here are the complete set of locks including ignition.
http://www.ebay.com/itm/New-Door-Ignition-Rear-Locks-Ford-Pinto-Wagon-71-72-73-/350438201739?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5197be998b&vxp=mtr
At $70.00 and 9.00 shipping it might be cheaper to replace all of them instead of just doing one and having a locksmith do it. That's if you can do it yourself I guess.
Vehicles:
289Wagon
 I meant that the door & L/G lock cylinders are different. I realize that in the case of everything being 'original' they would be keyed alike.                However weather he gets a new or used lock cylinder it will need to be rekeyed to match his door key. I'm pretty sure any good locksmith                can do that in 15 minutes or less.
dianne
Found the trunk lock only for $25.00 on ebay and $6.00 shipping if you don't mind them not matching. You could probably get a locksmith to rekey it to match for you also!
Vehicles:
dianne
These are a set of all the locks and keys. Mine is a 1973 wagon and it uses the same key in everything!
Vehicles:
Mine is original and it uses the same key too.
ToniJ1960
 They are different but my cars always used the same key. Probably people selling them in sets with the d oor locks.
289Wagon
 If you are unable to locate a used one, Miller Obsolete Parts shows one in stock. (lock & keys)  $35 + ship
Yes, they are different than the doors.
mrmellowgold
My 73 wagon is missing the lock cylinder for the rear tailgate. It's just a hole, but the bad thing is that someone can just wiggle there finger around in there and open the hatch with a push of a lever on the left inside. I have been looking around on ebay, but I only find door lock cylinders. (I hope my terminology is correct, correct me if I'm wrong)
So does anyone know where to find one for the tailgate or can I order and install one made for the door?
I don't need anyone steeling my infinity speakers and box i just got for it :)
