Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 02/03/2018 11:28 am
Date: 03/13/2021 12:57 pm
Date: 08/08/2018 12:26 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Squire trim
Date: 03/28/2018 10:11 am
72 pinto
Date: 06/23/2016 12:40 pm
  • Online today: 288
  • Guests: 289
  • Total: 289
Engine and transmission mount/bushing
Started by mrmellowgold, October 21, 2013, 12:30:02 PM
jeremysdad
I got mine from O'Reilly. Cheaper than dirt...less than $15 for all 3. And this is where the fun began, for me. lol
Lot's of prying, cursing, and jacks involved. In hindsight...save yourself some trouble, and shave a 1/4 inch off the top and bottom studs on the engine mounts. Transmission mount...either wait for the right one, or prepare to drill holes, depending on build date. (early 2.0)
tbucketjack
Rock Auto was the only source of a transmission mount and very reasonable. All the other local parts places had to order them and much pricer. Good Luck
HOSS429
yes dozens on ebay ... if the mounts are broken you will have a difficult time removing them as they have a nut on top and bottom .. you will have to find a way to keep the mount from spinning as you try to remove the nut .. perhaps the weight of the engine will hold it in place .. you just need to lift the engine a couple of inches after you pull the upper and lower nuts off .. the trans mount is easier ..
PintoMan1
1973 pinto runabout
dennisofaz
Hi,
Check Rockauto, they have a lot of parts for good prices.
Dennis
mrmellowgold
Hey there! I was wondering how I would go about putting on new rubber mounts or bushings on my 1973 Pinto wagon. The engine rubber mounts are old and falling apart, and the transmission rubber mount is all old and coming right off with a poke of a stick.
How do I put them on? and where can I find the proper ones? Any website that sells them?
