Date: 10/24/2019 01:45 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 10/03/2018 10:46 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 01/28/2017 12:30 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 06/28/2019 09:14 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
  • Online today: 489
  • Guests: 208
  • Total: 208
Head gasket question
Started by Jerry merrill, October 14, 2013, 10:26:14 AM
HOSS429
iv`e used double head gaskets before to lower compression on an engine i built .. no problems .. GM did it in the early 60`s to some 409 engines from the factory .. they built the engines with high compression but added an extra gasket to bring it down a bit for stock class rules then the owner simply pulled out one gasket and went racing ...or something like that .. yes double up on felpro gaskets and dont worry ...
Jerry merrill
I have a cylinder head for a 2300 that has been milled about .130 which is too much compression ratio, about 11-1. Has any body used  Fel-Pro's head saver shim? It is .20 thick and should lower it about 1/2 pt. Can you use more than one of these?
