2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Seeking parts
Date: 10/18/2020 10:35 am
V8 rear end
Date: 04/12/2018 10:57 am
Date: 12/24/2016 04:13 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 08/09/2018 11:09 am
  • Online today: 548
1977 Pinto V6 T-stat
Started by totljeep, October 04, 2013, 03:56:54 PM
totljeep
I'm pretty sure a head gasket is the problem. Will a 2.8 from a 1984 Ranger swap in place or is there any difference?
FIX MY PINTO ELSE I'LL DRIVE IT LIKE IT IS!
jeremysdad
You'll want to clear that hose fitting out. Could be part of your issue. You might want to check all your other connections for clogs, and then run a couple cycles of 'Super Cooling System Flush' through it. Sounds like it may have been neglected by a PO at some point.
Good luck!
flash041
The small hose ,5/8 dia, is the heater hose. dont know what you mean by" no opening for coolant to flow" unless it is corroded shut.
totljeep
What is the purpose of the small hose to the T-Stat housing? There is no opening for coolant to flow. Anyone know?
Had to replace my fan to get my b6 to run cooler, can run a/c on hot fl days or it gets to hot for me to be ok with sure the car would be ok but don't want to blow motor! Good luck n hope u fund your over hearing issue
totljeep
Quote from: flash041 on October 05, 2013, 01:55:21 PM
The thermostat is at the lower radiator hose. The housing is located in front of the water pump. There are three 10mm headed bolts holding it on. They thread into a 90 degree bypass nipple behind the timing cover.You will need a new thermostat, flat rubber gasket, housing gasket, nipple gasket. Its a bit tricky getting it all in place to bolt together.You said its running hot. How hot? I have had mine since new and it most always runs at the high end of normal on the factory gauge.
I don't have a temp gauge so I don't know exactly how hot but the coolant is boiling through the hose at the cap so I also installed a new rad cap.
flash041
jeremysdad
On the v6, I believe they're located at the bottom front of the motor.
Here's a link with info: http://www.fordpinto.com/general-pinto-talk/running-warm/msg27994/#msg27994
totljeep
Can someone please tell me how to find and change the thermostat on this '77 w/2.8 V6. It's running hot so I'm gonna start there. Thanx a heap..
