Date: 10/24/2018 07:35 am
Date: 03/14/2020 01:52 pm
Date: 01/23/2023 02:22 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 07/01/2019 03:17 pm
pintos for sale
Date: 12/11/2018 04:29 pm
Date: 02/14/2018 01:34 am
Date: 02/14/2019 06:27 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
  • Online today: 645
  • Guests: 568
  • Total: 568
Mechanical fuel pump remove and replace help
Started by Garage8700, October 04, 2013, 12:30:03 PM
84 Ranger 2300 fuel pump is a direct bolt on and is upside down for more clearance.
That radiator hose is close to the pump, could get kinda warm in the summer time especially in the warmer climates...
FracMonkey
Uh...... yea, That does not go back on.
Great thread topic.
FracMonkey
Believe me, buckos, it existed.
302 version around '79................
http://vb.foureyedpride.com/showthread.php?151399-Picture-of-a-1979-Mustang-Fuel-Pump-Guard
Not the same shape at all but you get the idea. Some call it a heat shield, maybe they were getting concerned about heat soaking into pump to make vapor lock???
Quote from: Scott Hamilton on April 07, 2014, 11:11:04 PM
I would like to see photos of this- I honestly had no idea a guard was placed on the pump of later model pintos-
Interesting....
I'd like to see that also..
Scott Hamilton
Quote from: amc49 on October 05, 2013, 07:37:48 AM
I remember cursing that guard on my '80, someone at Ford freaked over the Pinto scare, they even put a bullet proof shield over the fuel pump to stop impact from accident starting fire up front on motor. Talk about overkill.............I left it off mine after pump was changed.
Interesting....
boughtabobcat
I just replaced the mechanical fuel pump on my 78 Bobcat wagon and ran into a similar issue (at dusk, on the side of the road, no less.) what I needed to do was to disconnect the power steering pump bracket, slide the ps pump up to where I could set it on top of the windshield washer fluid reservoir, then the small arm that bolts to the side of the ps pump could be rotated upward and back and gave me access to the rear bolt using a deepwell 1/2 inch socket and a 2 inch extension- hope that helps!
D.R.Ball
Garage8700
A friend has a 79 Pinto with a carb 2.3 liter. The car has only 19K on it and the mechanical fuel pump went away. Getting the replacement pump was easy since I work for Advance Auto the hard part is getting to the pump bolts on the lower side of the motor. There appears to be some sort of crash guard wrapped around the pump and getting to the rear most bolt has turned into a Rubix cube of sorts No direct shot at it It appears that the driver motor mount and bracket may have to be removed in order to gain access to it? Don't know. Any help and assistance on this one would be greatly appreciated.
Yes! You saw it right 19K miles! Want to keep this jewel alive and original.
