1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 01/30/2017 01:48 pm
Date: 10/01/2020 02:00 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 04/15/2017 05:14 pm
Date: 07/17/2018 09:49 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
  • Online today: 452
  • Guests: 386
  • Total: 386
Flexplate spacer
Started by RichFox, September 25, 2013, 02:45:34 PM
RichFox
I believe the spacer was to enable the use of an available flex plate when using an automatic behind the 2.8. As previously mentioned, the block was not designed for automatics when it was a V4. However I do have a spacer "In the mail" So I hope I can get this thing together.
I ran a 2000cc Pinto in my roadster at El Mirage for some time. My driver had a MG Midget with a Capri 2000 and automatic with a Corvair Turbocharger I loaned him. I liked those motors. Hard to break them. Now I am trying to deal with a 2.8 V6 in a Bantam pickup for the street.
jeremysdad
I hadn't either, but I bet a 3.0's internal would bolt right in, and if you wanted to source the parts...so too, would the transmission. :)
Quote from: jeremysdad on September 27, 2013, 12:18:53 PM
Venturing a guess...to space the flexplate out from the crankshaft? J/k!!! O.o
Well duhhh, LMAO...
QuoteSeriously, probably a difference between European and American transmissions. Specifically, I bet there was no auto offered behind the motor in Europe. Just my 2 cents.
Hmmm, never thought about that could very well be the reason.
jeremysdad
Quote from: 74 PintoWagon on September 27, 2013, 10:37:41 AM
Well I'll be dipped, never seen or heard of anything like that, learn something new every day.. Wonder what the purpose of it is????.
289Wagon
 In my 40+ years in the auto & heavy truck field I too had never seen any sort of spacer  ***BUT*** the Ford parts book does list one !!!
And there are 4 of them available NOS.
Maybe he's talking about the spacer plate between the bellhousing and the block????.. Can't imagine a spacer between the crank and flexplate???..
Generally the crank then flywheel or flexplate-now there can be what seems to be a spacer OUTBOARD of the flexplate, not behind it. It reinforces wheel there at bolt holes to prevent cracks.
What makes you think something else goes there?
The converter when  all the way back must just clear any studs if present on that one, you then pull the converter forward to engage studs or bolts in holes. Meaning converter can seem awful far back, like too far. If flywheel, converter, trans case all correct you simply pull converter forward and button it up to plate.
I've never seen any sort of part bolted between crank and flywheel/flexplate on any engine I've ever worked on, engineering frowns upon that, it makes the bolts much weaker and prone to break.
RichFox
I believe there must be a spacer between the crankshaft and the flexplate in a 74 Bobcat with the 2.8 V6 and a C4. But I don;t have one. Am I correct and where can I get one or the measurement of the thickness required to make one? Thank you Rich Fox
