Early 2.0 engines
Date: 05/09/2018 12:45 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 09/09/2018 03:22 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
looking for parts
Date: 06/19/2020 02:32 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
72 Pinto
Date: 03/07/2019 12:07 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
  • Online today: 531
  • Guests: 538
  • Total: 538
stock AM radio connection wires
Started by renton481, June 14, 2005, 09:47:52 PM
renton481
Hey all,
Thanks for the responses.
I just installed a replacement AM radio and your answers were helpful.
I just put a 1970 Philco AM radio in my Pinto -- it was originally in a Fairlane or Montego (acc. to the Sams specs).  It sounds miles better than my original radio did -- for one thing, no ignition interference (thanks to the 1970 radio having a spark plate).
Now all I need to do it fix or alter the plastic cowl, then it will look better in the car......
pintoman
The yellow wire is the ignition lead[12v's when the key is on],the blue wire is for when you have the dash lights on.I believe the four wire plug is for the speakers,and the black wire is the ground wire.
billnall
A stock radio has a 2 wire black rubber plug for the speaker.
I do not remember what the other the other plug looks like, but should have at least 3 wires, 1 for power,
1 for light, 1 for ground.
Ford Parts Man
If I remember correctly, the two prong connector is for power.  One lead for the radio the other is for the face plate light ( I believe the blue wire).  I assume the 4 wire plug is for the speakers.  The radio housing needs to be grounded for it to work.  Hope this helps....
renton481
Hi guys,
Another dumb question from a newbie.
The stock AM radio on my 79 wagon bit the dust a couple months ago...  so I found a replacement -- actually two.
I took the bad radio out, and found it's an Audiovox.  The replacements I've got are both 70's Philcos.  One is identical to the one that was in the 1970 Maverick my family had when I learned to drive, and has larger dimensions than the Audiovox.  The second Philco I've got is a later model that has the same exact dimensions as the Audiovox.  Both have different wiring than the Audiovox.... and that's the problem.
Can someone explain the Pinto's radio connection cables?   There's a black connector that has a yellow wire and blue wire.  There's another connector (light yellow plastic) that has four wires coming from it.
The Audiovox radio also has a black wire that looks like a ground wire, and the obvious antenna jack.
Altogether, that seems like a lot of wires.
