Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Date: 12/13/2016 10:25 am
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 01/23/2023 02:22 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
  • Online today: 2,622
  • Guests: 2568
  • Total: 2568
motor mounts for 2.3 turbo.
Started by L.D, September 13, 2013, 07:17:22 PM
Here are a couple of pictures of my 2.3 Turbo in a '73 wagon.  You might have it slightly easier because the '73 has a odd one year only rack that has a bulbous knob on it.
As it regards the passenger side (showing in the picture), and the lower front threaded bolt hole in the frame rail; my lower front mount hole (center) is 3/4" down and 1/4" to the rear of that hole. You can faintly see this in the first picture. If you can enlarge it, it may help.  I don't remember grinding other than removing the old mounts. Likely every car is different so my measurement should just be considered ballpark.
I had my engine in/out 7 times before I was willing to commit. Every car is likely different  and everything it SO tight, probably 3/16" clearance at the rack, oil pan, starter bearing and hood (also 1/4" at the pulley bolt to radiator).
All the best.  Frankly pulling the trigger on the MIG was like saying "I do" at my wedding.
Tom
L.D
starting to mock up my motor mounts in my 71 for 2.3 merkur swap and a t-9 looking at some recent photos it looks like one of the holes just about lines up with the exiting nuts. Do you have to cut the back side of the mount that is going to be welded to the frame because of the flare on the bottom of the frame going towards the cross member or gring that area flat?
