door sills
Date: 03/14/2020 03:20 pm
Date: 04/27/2018 10:28 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Crane Cam
Date: 02/26/2018 07:50 am
Pinto Watch
Date: 06/22/2019 07:16 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 04/24/2018 11:45 am
Date: 09/26/2019 05:31 pm
Date: 02/05/2017 09:45 am
  • Online today: 553
  • Guests: 189
  • Total: 189
Vin #'s
Started by Stuwil, September 07, 2013, 06:58:03 PM
Quote from: Stuwil on September 08, 2013, 11:40:29 AM
the bell housing and trans are all one piece
the only other number on the sticker is
F02197R1234
my feeling is it's a C6
any reason to keep it? Is it a better trans for a V8 swap?
The "Small Block C-6" is getting hard to find and can take some serious torque if in good shape. I took the FMX (heavy) trans out of my 69 351W Mustang and put in the lighter, stronger C-6. I'm putting out about 380ft lbs and there is little or no support for the FMX. There are people out there looking for your C-6.
Stuwil
F02197R1234
righthandman
I'm not real sure that the trans was coded in the v.i.n. in 74, but every Ford built during the 70's had a code sticker on the drivers side door jamb. If you could get the trans code from that or get a picture or two (including one of the pan) from your trans. I'm sure someone here could tell you with certainty what you have.
I have a 71 E300 14' box van with a 302 and a C4 automatic. So they did use the C4 in some bigger trucks.
I think all the C4's unbolt from the bell housing, but the C6 does not. There casing is molded to bolt to certain size engines.
Stuwil
jeremysdad
Should be a c-6, if it's a van.
Stuwil
I picked a 74 e150 with 351W in it. Only 39000 on the clock and I'm certain that is correct. I know the previous owner. Just got the engine and trans out. My question is what is the tranny? vin is   E14hha03293. (the zero could be an "Oh") Does that tell me anything? This transmission looks big. The differential looks way big too.
It has been sittin for over 20 years, would be cool to hear it run again.
Thanks for any help I can get
