Bumper Guards
Date: 03/28/2017 09:27 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 02/28/2018 09:18 am
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Radiator
Date: 05/27/2018 06:07 am
SVO SWAP
Date: 03/15/2018 03:12 am
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
  • Online today: 481
  • Guests: 252
  • Total: 252
Good rear end gears for an 8 inch with a 2.3/t5?
Started by pintoguy76, September 02, 2013, 01:59:19 PM
For what it's worth: Since I recently swapped out my 3.00 for a 3.40 I did a search regarding just using RTV or using it with a gasket.  The overwhelming consensus was that the gasket eventually wicks the gear oil and leaks.  Thus the advice I took away was to use RTV without the gasket.
  There was an argument  about wheel bearing alignment without the gasket thickness.  It was stated that the offset was virtually unmeasurable over the axle length and not to worry about it.
Mike Modified
Quote from: dick1172762 on September 06, 2013, 08:50:33 AM
If you don't want to use RTV, where is a good place to find the 8" gasket? I've looked all over for some with no luck. Thanks for any help.
Fel-Pro RDS13270 or Victor Reinz P27807.  If your parts store can't get one or the other, find a better store.   :)
I wouldn't necessarily say "useless."  The Turbo Coupe weighs about a 1,000 pounds more than the Pinto, used taller 225-60-16" tires and had 3.55 with the T-5.  I never felt like it need a lower (numerically higher) rear ratio.
  Currently my (Turbo) Pinto has a 3.40 with 215-60-14" tires and is right about 2,500 RPM at 65 MPH in 5th gear. I see no issue.  Even when I had a 3.00 and was turn 2,000 RPM at 65 MPH the overdrive served its intended purpose.  That being to lower the RPM and effectively save fuel. If a car is normally aspirated it may be challenged, but with the turbo it seems capable.  Frankly I never notice a overwhelming significant difference between 3.00 and 3.40 as it related to acceleration. The change to 3.40 was more a matter of drive-ability to a certain speed (limit) - in a particular gear that was most noticeable.
It is all about application (daily driver, drag racer etc.), transmission ratios, and a factored combination of tires size and rear end ratios.  There is no "one size fits all."  As an example, I know someone with an SVO Mustang (3.73 rear/225-50-16" tires) and he utterly bemoans how low 1st gear (3.97) is in the T-5 (not 5th gear).  Were he to have the mentioned 4.11's he would probably be out right screaming.
Tom
Billnparts
The 3:40 is ideal with the 4 speed. I'm running 235/60R15's on an 8" axle with 4:11 posi through a T5. Final drive in 5th overdrive computes back to 3:40. If you start with a 3:40 in overdrive 5th you'll effectively be running 2:80's making 5th gear useless.
Billderbeast
All  8" rears have 28 spline axles. I've never seen any other spline count listed
Yea, I guess I should have said, " backing plates UNBOLTED and the axles slid out." In my mind I was "removing" (as in "releasing") the plates from the housing (but not removing them so as to disassociated them from the other involved parts).  So, I see how it could be considered otherwise.
Why..., your just like my wife, you don't understand me at all. LOL  :)
Tom
Mike Modified
Quote from: Wittsend on September 03, 2013, 01:19:19 PM
I'm not sure if you have ever done this before, but the axles need to be slid out of the third member and then the brake backing plates removed.
Apologies!   :D   A minor tweek to avoid confusion.
To my knowledge (somewhat limited) I believe any Ford 8" third member will fit any Ford 8" axle housing.  When you get into the performance products there may be different spline counts on the axles. But, as far as I know, stock they are the same. My housing was out of a Mustang II and the third member from a Bobcat.
I'm not sure if you have ever done this before, but the brake backing plates need to be removed and the axles slid out of the third member. Often the third member doesn't want to slide right out, but when it eventually does you realize how heavy it is. Be safe and have the help and tools needed.
When I checked the Internet most people did not use a gasket on the re-install.  If I ever did it again (and I'm hoping not to) I would get the third member situated on the studs (not always easy - remember the difficulty in getting it out). I would keep it from falling with a few loose nuts and THEN apply the RTV sealant.  With the pointed tip it should get between the housing and the third member.  I put my RTV on first and then struggled (by myself - thus, the reason I recommended help) to get the third member on the studs.  By the time I finally got everything aligned the RTV was rather (as in too) tacky.
Lastly don't forget to refill the housing with gear oil.  It likely dripped all over you during the process and the smell that doesn't go away for a day or so should help to remind you.  I have a friend with a Cobra replica that made that error. When the rear locked up it cause the car to spin and crash.  It also broke teeth in the transmission. In the end it was a $2,000 repair.
I'm using stock 13" tires. I'm thinking the 3.40's might be best. Will any 8" third member fit?
Unless your going to go for aftermarket gears your basic (Ford) choices are 3.00, 3.40 or 3.55.  I was told that Ford did use a 3.25 in very limited 8" application but is difficult to find.  Tire size is also a factor to choosing rear ratios.  This leaves 3.40 or 3.55.  If your using 13" tires (or low profile 14" tires) I'd go with the 3.40.  If you move up to 15" or 16" I'd go with 3.55.
I had a 3.00 rear with my T-5 (and Turbo 2.3).  It just seemed like every gear was not right for the speed limit.  I went to 3.40 (currently 215-60-14" tires) and for everyday driving it is far more applicable. Interestingly, I did not find a substantial difference between the 3.00 and the 3.40 during flat out acceleration. But then the boost does come on strongly.
If you hunt the Pick N Pull type yards you will probably find the 8" ratios in this order of availability: 3.00 (about 60%), 3.55 ( about 30%) then 3.40 (less than 10%).  So, if your looking for a 3.40 don't pass opportunities to do so.  There are door sticker codes available on the internet to simplify locating the desired ratio (without having to crawl under every car).  That said, I'd still do a rotation check before going to the trouble to pull the third member.  Lastly make sure you take the ID tag.  I see they are going for about $20 on Ebay.
A few trips ago to the self serve yards I found a 3.40 tag lying on the ground.  I picked it up and tossed it in my tool bag. Wouldn't you know the next trip I found a 3.40 - less the tag. The door sticker  I.D-ed as a 3.40 and the rotation confirmed it.
Tom
I have a 73 Runabout with Ranger 94 2.3 with 5 speed. 3.40 - 3.55 works good for me.   Fred   :)
What gears would work good with a 2.3 (DIS EFI from 91 mustang) and a T5 transmission? The rear end is 3.00 right now and that's too high.  Currently I even still have the 4 speed trans but it will eventually be a T5 so thats what I want to gear it for.
I'm thinking 3.25 or 3.40? What do you guys think?
