Date: 01/19/2020 09:06 am
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 06/22/2017 07:19 am
Date: 12/13/2016 10:25 am
Date: 02/21/2022 11:11 pm
Radiator
Date: 05/27/2018 06:07 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 12/26/2016 04:29 pm
Date: 01/28/2019 05:15 pm
  • Online today: 295
  • Guests: 211
  • Total: 211
Where does negative battery terminal bolt to? Body or motor,
Started by gaeliccouple, August 21, 2013, 08:36:18 AM
Actually, a known brand new battery can measure at ideal temp and specific gravity up to 12.86 volts. When testing at the auto store it became obvious after a while that cars running battery at 12.5-12.7 had no troubles and cars that drop below 12.3 start showing trouble, although some oddball cars can start at as low as 11.5 volts (some Hondas). Using 12.3 as the low cutoff spot has worked well for me. So, at least 13 volt minimum needed to me. 13.8 on these older non-PCM cars would be great.
ToniJ1960
 13.8 is the nominal charging voltage for most `12 volt` systems. Whenever I build regulated 12v supplies I always try to get right at 13.8
If the voltage from the alternator doesnt go over 12.36 or something like that it wont charge the battery at least not well. NiCad and NIMH batteries are charged with a constant current. Lead acid usually charges in 2 parts with higher current then a voltage leveling. Some chargers change states.
The alternator output is controlled by the regulator by controlling current through the field winding. The regulator is a little different than a series regulator in normal power supply but in some ways not a lot.
I always try to maintain 13.8 always been good for me..
There may well have been something wrong with the regulator, BUT, all alternators on earth must supply more voltage than the 12 volts of the battery. If they have same volts as battery then they are not charging. I look for like 13-13.5 on these, 14 is not that high. As example the Focus charges at 14-14.5, if below 14 the alt has popped a diode and long term will run the battery down.
What they said on extra grounds, you can never have too much ground. Should be a minimum of battery to chassis and battery to block always.
gaeliccouple
Problem solved! I went to the parts store and had them retest the alternator and it's results read "high voltage". The Alt was giving the battery 14 volts instead of the proper 12. So I replaced the voltage regulator and put a ground wire between the motor and chassis to ensure I had a good ground.
The car runs great now.  Before this repair I could hear the motor's RPMs drop noticeably when I turned on the headlights. The alternator was demanding a lot of power from the motor such that the motor would stall out went it was cold. Now when I turn on the headlights the RPMs stay the same and the headlights brightness does chance with the change in the motor's RPMs and the car has more horsepower when driving. Even the radio sounds better.
Thanks to all who responded.
jeremysdad
Quote from: Fred Morgan on August 21, 2013, 02:21:38 PM
Only if you have a diode out in alt..   Fred   :)
If properly grounded, then Fred nailed it. It's a simple system. If it dims off idle (at higher rpm), and is grounded properly and all other connections are correct, then go back to the alt/voltage regulator. :)
Ymmv.
HOSS429
Quote from: gaeliccouple on August 21, 2013, 02:10:08 PM
IS IT NORMAL FOR YOUR PINTOS TO HAVE THE HEADLIGHTS NOTICEABLY GROW BRIGHTER AND DIMMER WITH THE CHANGING OF THE RPMs?
NO .. you still have a problem ..we just dont think the ground cable will solve it .. or at least i dont think it will .. i`ve had a similar problem years ago but dont remember the remedy .. someone will think of it directly ...
gaeliccouple
Thanks guys, I'll try adding ground straps between motor and body the 2x method suggested. My next question is
jeremysdad
Proper ground circuit (stock): Batt to block, block to chassis.
Improved: Batt to block, batt to body; block to chassis (2x).
What rpm is this dimming occurring? If at idle, that's normal, if you're still running halogen lights. My brand new 2002 Ranger did that, back in the day.
If you don't have the starter grounded, it won't spin. That's why when you test a starter out of a vehicle, you have to connect the ground cable to one ear. :) That's why, when you changed the batt ground to the body, it wouldn't do anything. Electricity makes a loop. Break the loop, it doesn't go anywhere. Ground the motor to the chassis (2x really only needed if you're adding a system or some other high-amp draw, but it never hurts).
This is what I did to my 79 Pinchero, engine to wheel well then to battery.  Fred   :)
ToniJ1960
Quote from: HOSS429 on August 21, 2013, 09:06:59 AM
i think he said he took the ground cable away from the block and put it on the body .. therefore it would not turn over .. you can put a ground wire from the engine to the body anywhere you wish .. it seems you dont have one now which may indicate the engine has been out of the car once or so .. many times that little cable is left off by mechanics in a hurry to make a buck ...but i doubt that is yor problem ..
Thats what it sounds like to me too.
A bad ground from the battery to the headlights would increase resistance in that circuit and create a voltage drop in relationship to the current drawn through it. I dont think it would cause the headlights to dim and flare with engine rpm.
Check the voltage at the battery with a decent dmm set on 20 volts range and get somepne to raise and lower the engine speed or do it yourself with the throttle cable, and see if the voltage on  the battery changes too. Or read on the actual battery connectors and at the battery posts while engine speed is raised and lowered.
I think its most likely a source voltage variance.
HOSS429
Quote from: Cookieboystoys on August 21, 2013, 08:44:50 AM
. I wonder why when you add the battery/body ground it will not turn over? odd?
gaeliccouple
I have not as yet added a cable between the motor and body. I need to go to the parts store today. My battery positive goes to the solenoid and the negative to the engine block. That's it! where does the negative battery terminal on your pinto ground to? Please tell me the specific bolt location. Thank yhou
motor to body ground is usually behind the motor to body, not uncommon for it to get loose. I always add another engine/body ground up front. The negative battery to body is common, I just fixed/added that on one of mine. I wonder why when you add the battery/body ground it will not turn over? odd?
gaeliccouple
I'm having an electrical problem with my 1979. My headlights significantly dim and become brighter depending on the motors RPMs. I checked the battery and the alternator and both are good. I replaced these two parts and the regulator just 6 months ago. I'm thinking its a electrical ground problem.
Currently my negative battery terminal grounds directly to the engine block and the car runs fine, but the light act funny. Where does it bolt to on your pinto???
So I tried to ground the negative battery terminal to the body and the car wont even turn over which has me thinking that perhaps the motor itself is not properly grounded to the chassis.
Any thoughts before I have to pay a real mechanic to fix what must be a very simple problem. Maybe I need a ground cable between the motor and the frame? IDK
