1980 PINTO for sale
Date: 06/19/2017 02:51 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 08/13/2017 02:01 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 03/13/2021 12:57 pm
Date: 03/05/2017 03:27 pm
Date: 09/10/2018 10:41 pm
Date: 04/14/2023 06:15 am
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
  • Online today: 1,137
  • Guests: 663
  • Total: 663
Speedometer gears
Started by pintoguy76, August 15, 2013, 02:49:59 PM
Billnparts
The speedo gears are in the trans. How far off is the speedometer reading at 60? Increasing the number of teeth on the gear at the end of the cable will slow down the reading. Conversely, reducing the number of teeth will increase your reading. Basically, the change of one tooth will indicate a change in your reading of apx. 7mph.
Billderbeast
I swapped my 6.75" rear for an 8" rear but didn't get the speedo gear from the donor car. The 6.75 had a 3.55 ratio and the 8 has a 3.00 ratio. Tires are stock size. What gear do i need and where can I get it?? I dont even remember what color the gear is now or what color the donor cars gear was.
