78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 10/15/2017 10:03 am
Date: 12/31/2017 09:03 pm
Date: 02/16/2019 10:46 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 01/28/2021 03:49 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 07/04/2022 07:55 pm
  • Online today: 500
  • Guests: 281
  • Total: 281
Dash Pad Removal and Tach Install
Started by From_Jonah, August 11, 2013, 09:56:52 AM
Also if you do install cap I would not use glue that comes with it I would use silicone so it will be easy to remove after car gets wrecked and you want to install in next car as I did.   Fred   ;D
From_Jonah
Quote from: Cookieboystoys on August 11, 2013, 06:00:39 PM
What Fred Said... the 1979 I just did also had several smaller screws to remove besides the ones he mentioned + it's a yes. To remove the dash you have to have everything out vent-to-vent to reach all the screws.
Ouch. I'm lazy. It's no show car so a dash cap is just fine hahah
Quote from: Fred Morgan on August 11, 2013, 11:38:08 AM
There is a total of 6 each 5/16" nut's to remove and are difficult to get to so unless you are going to recover or replace I would go with dash cap.  Fred   :)
Guess there was a reason why it was for sale huh, LOL..
From_Jonah
Alright cool. Yeahhh, the second-hand tach I got doesn't work hahah.
Also, thanks Fred! I figured they had to make it difficult haha
289Wagon
 Like 74 PintoWagon wrote the tack wire (usually green) goes to the coil. NOTE: it gets attached to the NEG (-) post the same one the dist. wire is attached to.
You should have 3 wires(not counting the light)pos/neg and the tach wire(probably green?)that is the only wire to the coil. Connect the pos to a switched terminal the other to a good ground.
From_Jonah
Ok cool. Is it one side to the distributor coil
and one side to  ground?
Tach wire goes to the distributor side of the coil, make sure the tach is set to the number of cylinders. Can't help with the dash though.
From_Jonah
So, I'll group these two things together. How do you go about removing the dashpad? Does it mean taking the whole dash apart to do so?
Also, I've got a tach that I'd like to put in my car but I don't know where to wire it up at. I read something suggesting you wire it at the distributor? But I can't find where you would do that.
