1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 03/29/2019 07:20 am
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 03/25/2019 09:02 pm
Pinto drive train
Date: 06/29/2018 08:32 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
pintos for sale
Date: 12/11/2018 04:29 pm
  • Online today: 1,292
  • Guests: 461
  • Total: 461
Relocated Battery, Plus an Audio Upgrade
Started by From_Jonah, August 10, 2013, 08:46:16 PM
From_Jonah
Quote from: OhSix9 on August 12, 2013, 10:59:02 PM
Maybe stick a giant fuse at the battery. If you get a short in a long run like that to the switch it'll burn 'er down. or put the cutoff closer to the battery.
Hmm. Maybe right behind the passenger seat. Somewhere easily reachable. Or like you said, a fuse. I could get one of those big ones in a mounted case thing.
OhSix9
Virgil to Sid
From_Jonah
Ok awesome. And no problems so far. Seems to be pretty solid and charging as normal.
D.R.Ball
Yes to do two things , one to prevent the build up of both the gases and the rust that forms in the area......See the engine bay for more info. Summit has a complete sealed and vented battery box for about $75.00 and I'm using one on my pinto (T) build myself. How is the relocated ground working out ? No problems with charging etc. ?
From_Jonah
Quote from: D.R.Ball on August 11, 2013, 09:03:24 PM
So you ran the + wire from the solenoid to a hole in the fender and back into the cab along side of the plastic side cover ? Where did you route the - cable ? From where to the battery. I would think about getting a sealed battery box unless you like the gases that the battery vents while charging....Other wise it looks great.
Thanks! And right. And the - goes from the negative post, to a ground a drilled on a seat brace. I can take a picture tomorrow and show ya
And, will do. I should be able to get a battery box and run a little vent tube out somewhere shouldn't I?
D.R.Ball
Looks good, and it is unique which is the best part..
From_Jonah
I did. There was one good door panel so I used it as a stencil onto some mdf and made the new ones. The coverings are like Navajo blankets.
On another note, if anyone needs a door panel stencil, I'd be happy to make them one just for shipping and mdf cost.
From_Jonah
From_Jonah
Did a little work today to relocate my battery, also making a new place to mount my speakers.
I ran 2 gauge battery cable from the solenoid into the cab (with a grommet) and into the back under where the rear passenger seat would go. I then mounted my ground for the battery and put the battery in and got it all connected. As you can tell, I have an opening in the top of my speaker box to get the battery in and out. There's going to be a + cut off lever under the dash as soon as it comes in.
Overall, a pretty easy project done for fairly cheap. Now to just fix that trashy battery rot under the hood   :-\
