2 liter blocks and heads
Date: 03/28/2018 09:58 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 09/17/2024 12:35 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 04/27/2018 10:28 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 07/01/2019 03:17 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
  • Online today: 515
  • Guests: 311
  • Total: 311
79 bobcat 2.3 efi swap hood clearance issue
Started by Daniel76706, August 08, 2013, 09:18:46 PM
Daniel76706
Thanks. I haven't had much luck getting an answer to the hood issue.  What's the easiest intercooler to mount in the car?
OhSix9
The tallest part. the very top of the throttle body and the linkage will do fun stuff like jam open. it'll whack the hood just to the drivers side of center.  Pinto 5.0  Nope it cant its an early tall 0000 manifold not ::  where the upper meets the lower. no chopping and for sure no rotating.   the solutions are. drill new holes and lower the motor mounts, cut a hole in the hood and put on a scoop or just get a proper one, fuel rails are not the same from inline to 4 square, you need injectors anyway. efi and turbo intakes are the same year to year so your not getting an upgrade using the early svo one. . the only thing the inline one will give you is a little longer runner building a smidge more down low torque for a tradeoff of grief, crappy engine access and more grief... if it still doesn't fit with the short intake you can take the upper to your local welder and have them chop out a 3/8th's inch and weld it back up, sawsall and sand out the upper divider and knife edge your lower while its open (or not. it trades torque for rpm) . You can also rotate and reroute to your visual pleasure
semi related  you talked about maybe a turbo later, that means either repinning or replacing the harness to the ecu, said ecu and some sensors. cast pistons and 9 to 1 should take 7lbs intercooled on 91 without grenading. Please note the disclaimer of "Should"
Complete donor using everything but the longblock FTW.  Unless you pop in forged slugs NA inject it and enjoy it.
Virgil to Sid
I'm betting the upper intake could be cut, shortened & rotated the way the turbo upper is done.
Daniel76706
On my 79 bobcat 2.3 I am planning on doing an efi swap. The intake is an inline intake off an 84-85 mustang svo. I have not put the intake manifold on yet. But people keep saying it will contact the hood. What part would it hit and what's the easiest way short of ditching the manifold to solve this issue???
