Date: 08/30/2021 03:20 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 03/05/2017 03:27 pm
Date: 01/28/2019 05:15 pm
Date: 08/03/2018 09:19 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 07/01/2019 03:17 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
  • Online today: 529
  • Users: 1
  • Guests: 323
  • Total: 324
  • TommyT
78 Pinto rear axle modification
Started by 1olfrdanut, August 08, 2013, 02:40:45 PM
FYI, you have to pull axles to re-machine the ends anyway, you do not have to disassemble the center section to simply remove a side spider gear to measure how thick it is. An open rear, the gear comes right out with axle out. No need to disturb the ring and pinion at all there.
1olfrdanut
I am installing a complete 1978 Pinto power train in my 31 Model A pickup.  To do so will require narrowing the rear axle housing by 2.25"  (1.625" on each end) and shortening the splined end of each axle shaft by the same amount.  As a matter of choice, I prefer to modify the superior Pinto rear end as opposed to altering the noisy old Model A banjo axle.  I don't want to disturb the perfectly operating Pinto differential and carrier assembly, by dissembling the unit to measure the length of the spider gear splines. Can anyone provide me with the spline design dimensions for this 1.625'x28 assembly?   I have professional machining and welding capability to make the mods, but don't want to assume anything about these modifications without first doing do-diligent research.
Thank you, in advance, for any assistance you can provide. 1olfrdanut
