Rear brake shoes
Date: 01/23/2017 05:01 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 05/13/2021 05:33 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 08/22/2018 09:23 am
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
1978 hatch back
Date: 11/29/2019 03:18 pm
  • Online today: 267
  • Guests: 241
  • Total: 241
Locked tailgate
Started by From_Jonah, August 08, 2013, 01:28:06 PM
flash041
Another option is to crawl in the back and use an open end wrench and unbolt the lock catch from the body.  I did this once when my lick froze from rust. No drilling required.
HOSS429
Quote from: sedandelivery on August 09, 2013, 06:59:07 AM
Just for the heck of it take some ford keys with you and put them into the lock and jiggle them around, it may work. The lock used in the tailgate is much more forgiving than the one in the ignition. I have done the tailgate thing with sucess a few times.
excellant thought !!!  i had a key once that fit 3 dif fords i owned .....
From_Jonah
Okay awesome. Hopefully I can get it undone pretty easy. The hard part will be getting to it and getting the tailgate off the yard. The part of the junkyard where the car is is right by the guys pig pens and its like a huge swamp.
Are the latches pretty easy to change out?
sedandelivery
Maybe try and loosen the hinges from the top and that might give you enough room to get under the hatch to release the latch.  Be careful though as those hinges are under a load.
A good cordless drill starting small then stepping up until about 3/8" should be enough to remove the tumblers & once they are out it will turn with a big screwdriver. I've done this on several. Go slow & you will eventually get it.
I imagine  that if you drilled a big enough hole and stuck a screwdriver in in and turned it with vise grips it will unlock, then use your old lock and key to replace it.
From_Jonah
This weekend I'll hopefully be going to get the new tailgate for my car. The problem is, it's at a junk yard and its locked and has no key. Would I be able to drill out the lock cylinder and get it to unlock and just move my current latch into the new tailgate?
