Date: 04/07/2021 06:12 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
72 pinto
Date: 06/23/2016 12:40 pm
Date: 03/06/2017 01:19 am
Date: 12/31/2017 11:14 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 01/12/2019 10:19 am
Date: 06/28/2019 09:14 pm
  • Online today: 1,292
  • Guests: 560
  • Total: 560
reverse spring detent
Started by hawgdoctor, August 05, 2013, 04:40:17 PM
HOSS429
Quote from: From_Jonah on August 05, 2013, 10:16:09 PM
Not to jack this thread here... but would this problem cause this shifter to just flip flop around? The hatchback I drove yesterday was like that and I wasn't sure what the problem was.
quick answer ..... yes .....
From_Jonah
ToniJ1960
The corrugated rubber spring could be tore missing or the c clip might be off.
Here is a link with details about someone that had the same issue:
Transmission swap for Cruising Wagon/Bobcat hatchback
HOSS429
what you have is a very easy fix .. i just dont have pictures of what you need ..someone else will .. the shifter is held up by a rubber thingy that fits between the trans and the shifter ..it is held in place by a c clip .. you may need to replace the plastic thing that goes under the shift fork as well ...done it many times just too long ago ,,,,
hawgdoctor
Recently acquired a 72 Pinto wagon, 2.0 ohc & 4 spd manual trans. There is no spring resistance felt on the gear shift lever gate when engaging reverse, so it's too easy to engage reverse instead of 1st. Is the fix for this in the shifter extension housing on top of the trans or is it inside the trans with the gear selector shift rods? Do I have to remove the trans to fix it? If anyone can scan & email me a picture of the mechanism from a manual so I can see where I need to go I'd be grateful. Can't find anything on line.
