Date: 10/15/2017 10:03 am
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 11/11/2019 04:49 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 01/30/2017 01:48 pm
  • Online today: 500
  • Guests: 280
  • Total: 280
Conservative redline for rebuilt, stock 2000cc/4-speed?
Started by Flygirl62, July 26, 2013, 11:00:08 PM
Flygirl62
Thank you both!
Jerry, it's in good tune, definitely the best running stock engine that's ever been in the car. Why Ford couldn't make it run this good in the 70s is beyond me. Well, to be honest, it's taken some TLC to get it this far, so that might explain it.
Kevin, I suspected that the stock cam gives good torque but isn't designed for higher RPM. Touching 4500, it does seem like diminishing returns after that.
So, sounds like I'm in the ballpark, but it's nice to know I can indulge myself to 4,500 if I'd like.
72Wagon
I have had mine (not stock) north of 8000 rpm, 5000 to 6000 regularly.  The bottom end is stock.   The limiting factor is the stock camshaft, it limits output to about 4000 to 4500 rpms.
Kevin
1972 Wagon
Jerry merrill
4,500 is plenty safe for a 2.0, you could run that with out damage as long as the engine is in good tune. Have fun!
Flygirl62
Quick question. After 35 years and another engine rebuild, I finally added a tach and engine gauge cluster to my '73 Runabout.
I find that I've been shifting at about 3,000-ish RPM in normal driving, see 3,500 at 70MPH and don't take it past 4,000 at any time.
Not looking to wring the last horsepower out of it.
Does 4,000 sound like a conservative redline for Ladybug? Could I go to 4,500 for a few seconds, and not regularly, if I'm really looking for everything it's got? Feels like the power band must begin to flatten out north of 4,000, but not really sure.
Thing is, it sounds really good through about 3,500, and so I just want to stay in it a little longer.
If I remember correctly, the redline when new was quoted as 5,800. So maybe 4,500 isn't unreasonable?
