1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Date: 03/17/2019 10:15 pm
Date: 06/07/2018 01:45 am
nos core support
Date: 01/03/2020 09:39 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 03/13/2021 12:57 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
  • Online today: 450
  • Guests: 441
  • Total: 441
How do I adjust the doors on an 80 pinto
Started by besthubcaps1, July 24, 2013, 10:34:44 PM
besthubcaps1
First of all, welcome!  In order to PM (Private Message) another member, click on their screen name.  That will take you to their profile where you'll see a menu that includes "PM".  Click on that, type your message, and hit send.  The message will go to them and likely they will reply the same way.  You'll be notified when you have received a PM and you click on "My Messages" to read it or to reply.  Hope this helps!
Dwayne :)
dga57 - Moderator
besthubcaps1
I am new to this web site and I see members have parts I need but I don't see where to communicate directly to  person. I see one said PM me any help here.???
289Wagon
 The bushings aren't that difficult to replace. You can make a simple tool using a 'long' bolt & nut, some flat washers & a 3/8 drive socket.
However if you want to go OEM-NOS there are enough 'just enough' available to do your car. PM me if you want more info.
besthubcaps1
Thanks guys, my hinges are sloppy, any ideas where I could get new hinges.
Advance had the Help brand strikers cheap but I can't remember the part number
That's a lot of weight hanging on those hinges, probably wouldn't hurt to change the striker bolts either..
HOSS429
you most likely will need new door striker bolts  as well .. the shaking up and down of the door will have broken the plastic sleeve ..
Quote from: 74 PintoWagon on July 25, 2013, 08:51:13 AM
I'm gonna have to change mine or rebuild them, door drops a bit when you open it, them doors sure are heavy..
I weighed rusty sedan doors & they were 76 pounds. Figure 80 pounds with door panels, cranks, etc.
The impact braces are 14 pounds each by themselves
Are the door hinges tight & free of any slop? If not start there because worn hinges wont allow adjustment
besthubcaps1
How do I adjust the doors on an 80 Ford Pinto
