Rare parts for sale
Date: 09/10/2018 08:38 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 07/17/2018 09:22 pm
Date: 02/21/2022 11:11 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 11/08/2019 10:01 am
pintos for sale
Date: 12/11/2018 04:29 pm
  • Online today: 515
  • Guests: 459
  • Total: 459
Isolating exhaust leak
Started by Flygirl62, July 23, 2013, 03:02:07 AM
Flygirl62
Thanks, guys. I found it using y'all's suggestions. It was around the donut, 40 years old and I suppose it needed to be replaced. So that's what I did, and it worked!
I also didn't think it'd make that kind of sound, I suspected the exhaust manifold was leaking from one cylinder. But now it's nice and quiet; that little 2 liter sounds like its thrummy little self again.
HOSS429
"pht-pht-pht "  that`s also the sound an angry cat makes  :) .. mite want to look for that ....... HA !!!!
289Wagon
 Does your engine have an A.I.R pump, aka smog pump ?
Usually you can feel a leak with your hand but do it when the engines cold. You wont have much time before it gets hot to the touch so be quick. Check the manifold to head, the donut & the pipes.
no they don't use a gasket but that doesn't mean a leak can't occur. the donut area usually wont emit the type of sound that you describe. use a length of heater hose and hold one end to your ear and move the other around all areas of the system.
it should help you pinpoint the problem area
Flygirl62
2000cc, '73 Runabout. Car's running well, but what sounds like an exhaust leak is bugging me. I've been reading about other instances of this, but thought I'd ask.
It's a 'pht-pht-pht' sound that changes with RPM, most noticeable from 2000-3000 or so RPM in second and third gear, when the throttle is past 1/2.
Sounds like it's coming from the front of the car, but where I'm not sure. My guess is the manifold/head area, based on the sound, but wondering if the doughnut between the manifold and downtube is the problem?
How can I begin to isolate it?
Any common areas I might check?
The 2000cc doesn't use an exhaust manifold gasket, does it? If the manifold is warped or something, can a gasket be added?
And if it's in the doughnut area, do any of those exhaust wraps or JB Weld type products work?
