78 hatchback
Date: 03/12/2023 06:50 pm
Date: 05/15/2022 11:36 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 09/12/2018 12:33 pm
Date: 08/01/2018 01:27 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
  • Online today: 1,292
  • Guests: 743
  • Total: 743
Front window chrome removal
Started by Reeves1, July 21, 2013, 05:45:02 PM
It will not let me turn the words blue. If I try 27.5 times, it will sometimes turn all I want blue. I can then copy it. But I (normally) have lost my temper before I do it that many times  ;D
I should also have asked how to remove the drip chrome as well (along the roof, each side).
Thanks for the help guys !
Quote from: Reeves1 on July 25, 2013, 04:52:14 AM
Don't know what is wrong with the computer.....c an no longer copy.
Did lots of bug cleaning & no luck. Yet.
It wont let you highlight it blue or wont let you right click then copy?
Don't know what is wrong with the computer.....can no longer copy.
I always highlight & copy my text before posting because I've timed out & lost it all. It's a habit now & when it does that I just paste it back in & hit post.
Thanks for the replies guys !
Been having troubles posting. Type a reply, hit submit & it times out.....
DBSS1234
As Pinto5.0 stated you use the hooks to release the clips. Also do not forget to remove the screws that retain the clips at the very end of the lower trim piece. To access these correctly you may need to remove the fenders.
This is the tool.
http://www.ebay.com/itm/Brand-New-Windshield-Trim-Clip-Removal-Tool-/290946461338?pt=Motors_Car_Truck_Parts_Accessories&hash=item43bdc2ae9a&vxp=mtr
You slide it under the trim from the windshield side, not the outer edge, and slide along till you hit a clip. Then you gently pop the clip while slightly lifting the trim. Repeat about 25 or so times & you're done.
Need detailed instructions on how to do this. Just the chrome. Cutting all the rubber out to save the good glass.
Need a special tool ?
Part number & name of it if so.
Actually, need instructions to remove all the chrome.
None of it is going back on, but it's in good shape & do not want to wreck it.
