Date: 08/22/2018 09:23 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
nos core support
Date: 01/03/2020 09:39 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 03/25/2019 09:02 pm
  • Online today: 535
  • Guests: 334
  • Total: 334
Ignition & Carb Help Please
Started by 80_2.3_ESS, July 08, 2013, 01:16:51 PM
Try the 390 & see how it runs. If you can get it tuned then run it. It will be a little over carbed but as long as you aren't running too rich or lean & the throttle response is good it should work fine. Gas mileage wont be too bad if you keep your foot out of it. I have one of those Offy intakes for 2.0 & one for a 2.3. I always heard they didn't do a thing to increase power.
I have an MSD box & dizzy for my buggy & I heard the dizzy hits that intake as well. My buggy motor should be close to 11to1 compression & with the big solid cam, porting, big valves, header & dual Webers I should easily break 150 HP with it. That's plenty in a 900 pound rail.
Nothing wrong with keeping the carb. My '80 is staying carbed until my son proves himself behind the wheel. Once I think he can handle it then I'll drop in a turbo motor. I already clearance the inner fender for it.
80_2.3_ESS
Quote from: HOSS429 on July 09, 2013, 11:22:30 AM
at minimun get the master blaster 2 msd coil .. i had a bad problem fouling out plugs in my overly cammed up 429 tbird and the msd coil solved that .... and yes i used it with the stock ignition ..
I was planning on upgradibg my coil if I did stick with the factory ignition, which I probably will use.
As to what I have, yes, it works (intake and carb), but I wasnt sure if there was anything I should invest in while I have the motor out of the car and easily able to wrench on it. I wasnt sure if the 2-barrel carbs were better from a power standpoint over the old-school Holley 390's.
I know I can get 500 CFM 2-barrels from companies like Holley and Demon, but I thjlink that will get a little too extreme for my application.
There is also a 350 2-barrel from holley, but that would require a new intake and carb. Would this really be worth the extra money? I have a feeling it's not, but thought I'd ask anyways.
Yes I am keeping it a carborated motor. I will probably start with the parts I have to get it going and should I deciede to upgrade down the road, I can.
Nick in CT
1980 2.3L Pinto ESS
HOSS429
I have this setup for my buggy but I may put it on my '80 just for fun. I have the shorter Esslinger manifold instead of this home built version.
I expect it to drink gas & be tempermental at slow speeds but it's for my woodsbuggy & power should be amazing. Tuning IDF Webers is an art form in itself & you can spend a fortune buying emulsion tubes & jets. A good Holley 350 that's set up for a 4 banger with the adapter plate bolted to a knife edged turbo lower intake would be the ticket.
As for ignition there's nothing wrong with the Duraspark.
Use the original Ford system it's cheaper than the MSD and it's easy to trouble shoot, parts are cheap and it's what you have etc. I mean just how many of these boxes go bad ? Not many. The MSD is a nice way to spend money on something that's not broke in the first place. As for the intake/ carb system what do you have that works ? You can use the later Ranger intake and a 2 or 4 barrel carb Esslinger has those adapter plates to do the swap.
80_2.3_ESS
So I am in the middle of my 2.5 / T5 build for my Pinto and I am at a point where I need some help.
The motor that is going into the car is a 2.5 Stroker motor from a Ranger, with a hydrolic-lifter (non-roller rocker) head. The motor has been bored .030 over, and the pistons replaced with flat-tops to get a little higher compression. I will be using an Esslinger street cam and adjustable timing pulleys. I will be using a Schoenfeld header and running 2 1/2" pipe all the way back. Behind the motor will be a Centerforce dual friction clutch and a T5 from a 2.3l Mustang so I have the proper gear ratios.
The head is currently at a shop being put on a flow-bench and ported, and the head was decked a little to get a little higher compression as well, so that is being done as well to help power.
My questions come to the ignition and carb / intake.
Currently, I was planning on running an Offenhauser intake, with a Holley 390 4-barrel carb, and the factory ignition. I read someplace (cant rebember where), that an MSD distributor would not fit under the Offenhauser intake. Can anybody confirm this? I know I would need the MSD box as well, and that's not an issue.
I was wondering if this choice of parts would be ideal for this motor. Would I be better off with a 2-barrel carb and a different intake? I really like the looks of the individual Weber carbs, but that set-up is way too expensive for me.
Can anybody give some advice on which direction I should go? If a 2-barrel will only be a marginal increase in power, I will just use the stuff I have. However, if we are talking a large percent increase, it may be worth it.
And no, please don't suggest a turbo / V8 for more power LOL
EDIT: Forgot to add that I am swapping out the 3.00's in the rear end for a Posi unit with 3.55's. Rear end is a Ford 8" from a Mustang II.
Nick in CT
1980 2.3L Pinto ESS
