1972 Pinto for sale
Date: 05/19/2021 12:41 am
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 10/24/2019 01:43 pm
Date: 09/02/2021 08:21 am
SVO SWAP
Date: 03/15/2018 03:12 am
New cam
Date: 01/23/2017 05:11 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 04/07/2021 06:12 pm
  • Online today: 1,185
  • Guests: 511
  • Total: 511
Ac hookup
Started by mrheatinc, July 08, 2013, 12:05:06 AM
What works with non EFI cars will not work with the EEC IV system. There is allot more than just wiring up a second fan and the fan clutch on the compressor you need the wiring harness from an A/C equipped Ford Ranger , Mustang ETC with the 2.3 and the EFI or it will stall out. Get the book and have a look at how the system works. Just using the engine harness from the downer car is only half of the circuits you need to make the system operate , this is why most swaps with the 2.3 Turbo do not have the A/C hooked up unless they took the entire system to make things work. Have you taken a look at the complete manual for the car ? As I stated before, unless you have the EVTM for the car your taking the engine out of and understand how it works the engine will just go into limp home mode when you hit the A/C. Or it will just bog down. Either way will not work. Do a search at Turboford.org if you do not take my word for it. Or check with Vintage Air FAQ's etc.
bbobcat75
you definitely want the motor to idle up or it will run like crap! and want to stall!!
1975 mercury bobcat 2.8 auto
mrheatinc
of course the electric fan relay needs to energize with the clutch also. is it a concern that the motor needs to idle up for the extra drag of the compressor or something?
mrheatinc
i guess ill look into having hose made.  don't need all that wiring that i know of just need the low pressure switch to interrupt the power to the clutch from the pinto ac switch and it'll operate perfectly fine? I've wired many ac systems in cars and semi trucks like this. I'm not gonna change the dash control. unless I'm mistaken. any idea who makes hoses?
Get a new hose made there are no adapters. Do you have all of the switches and sensors from the Thunderbird ? If you did not, good luck. The original A/C system in the Pinto was pretty simple however you have about 4 or 5 other sensors on the T-bird. I would get a hold of a Ford Thunderbird "Electrical, Vacuum and Troubleshooting Guide " from Helm or Ebay.com before you do your swap. When the A/C system is on allot of other systems on the engine also have to work in sync or your engine will not run very well or at all. This is why this summer my Pinto will not have A/C.  Has anyone here just dropped in the Turbo engine and played plug and play with the A/C ? I do not think so. The engine swap is just the tip of the iceberg for getting the Pinto updated. You could try to piece something from a Mid 85 and up Ford Ranger or Mustang but you need to learn what's what and where these parts are and how they work with the EEC etc. The guide will show you they why and how these things work. Did you get any of the other parts from the T-Bird ? Receiver/drier, the other engine fan for the A/C  Condenser etc. not allot of the Pinto parts can back fit with the EEC IV controls.
mrheatinc
I have 77 wagon that I have an 87 turbo coupe engine I will put in it. Right now I am transferring the compressor to existing engine because I got the can with no existing compressor or brackets. My issue is the existing lines have screw on fittings and the compressor has spring lock. What is the easiest way to adapt to the low mount more modern compressor?
