Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 02/05/2020 11:06 am
1978 pinto grill
Date: 07/24/2018 02:18 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 04/06/2017 12:13 am
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 07/01/2019 12:23 pm
  • Online today: 600
  • Guests: 323
  • Total: 323
93 DIS 2.3 swap into 79 bobcat
Started by Hoffmanfabrications, July 06, 2013, 05:53:50 PM
hurm2006
Glad you got it to work, its great how the engine harness is mostly self contained and you only need a few wires to make it work. The reason I did mine was that most people change the intake and slap a carb on and go. I wanted to be different but am glad I did go with the injection as the fuel mileage is great
'77 Sedan:   fuel injected High Output 5.0, 5 speed, 26 MPG!!! daily driver
Hoffmanfabrications
Thank you hurm2006 for your help. The schematic u provided was correct. All the wiring was the same as a 5.0 only I didn't need a few wires on the brown connector by the master cylinder. Car runs great! Haven't driven it yet, just gotta put a power steering pump on it and its ready to roll. After its all said and done, it was a lot easier than I thought it was gonna be and I'm glad I did it!!!
hurm2006
the truck intake is way to tall to fit in a pinto, the stock mustang one is even slightly to tall, i have spacers on my hood hinges for clearance. One good information site that helped me (mostly 5.0 info) http://www.veryuseful.com/mustang/tech/
Also im using for daily driver with the 5 speed its easy to keep the rpm below 2000, with 2.73 rear gears i run about 1600 at 55-60mph
Hoffmanfabrications
Thanks, I'll look into that. Gonna try n get it started this week sometime.  I like the schematic, where did u find that one? Also I have a 92 ford truck with the 5.0, how hard is it to swap that into the pinto? Just curious in case I wanna try it later on. My main goal is gas mileage, but if you are getting 26 mpg with a 5.0, I might try it!
hurm2006
you should be able to use the engine harness and just add your own wiring to the other side of a few of the plugs, I did this when installing a 5.0 in my car, there are a couple plugs by the master cylinder and 1 or 2 buy the ecm that need some wires hooked up (at least on the 5.0 engine harness.
here is a pinout of the 93 2.3 ecm (USE AT OWN RISK)
Hoffmanfabrications
Hi everybody, so I'm swapping a DIS setup out of a 93 mustang into my bobcat, I'm wondering if I can delete the dash harness and just use the ECM harnes? Only problem is that I can't find any good schematics for that. Is there a way to do that or do I have to use the dash harness? I don't want to replace all the wiring. Thanks for any help.
