2 Station Wagons for sale
Date: 04/20/2018 11:10 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 05/13/2021 05:33 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 08/27/2018 11:11 am
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 09/06/2020 01:57 am
Date: 11/11/2019 03:38 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
  • Online today: 535
  • Guests: 336
  • Total: 336
Budget Pro-Touring suspension upgrades??
Started by 59F100, June 23, 2013, 03:12:56 PM
Mike Modified
I much prefer to use Chassis Engineering's (the one in Iowa) AU-2045 caliper adapter kit which uses 80's Mustang/Thunderbird calipers instead of the GM metric caliper that all the other kits use. http://www.chassisengineeringinc.com/disk-brake-kit-1940-1948-chevy/
OBTW, their new website is up, but a real mess: that kit is located only in the *hevy  section.
59F100
Starting a 1976 Wagon daily driver?Pro-Touring build and I'm looking for suspension, rear axle upgrades. It's a low mileage car but still needs some suspension help bushings, steering, ball joints, etc... So I was thinking tubular a-arms would be a nice upgrade at the same time replacing the worn ball joints and bushings. shorter stiffer springs, possibly dropped spindles. 11" granada rotors/gm calipers to upsize and convert to 5 on 4.5" pattern. I have a 95 Explorer rear end with 3.73 gears and posi. If I shorten the drivers side to match the short passenger side axle the pinion is still offset about 2" and approx the same width as the stock 6.75 rear. Looking for do/don't advise. Thanks
