2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 06/24/2020 06:12 am
Date: 07/10/2016 10:17 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 04/04/2020 09:38 am
Date: 02/25/2017 08:45 pm
  • Online today: 553
  • Guests: 432
  • Total: 432
Any advice on adding after market air conditioning?
Started by Runabout75, June 20, 2013, 07:49:32 PM
tbucketjack
I would look into a Hot Rod Air, Vintage Air, or Southern Rods under the dash unit. If your heater is also gone you can got with a unit with both heat, a/c, and defrost. There are bracket mfg like Allan Grove that may help if the kits do not fit your application completely. The all have a slim line under dash unit. I used one in a 1949 Ford F-1. Good Luck
Runabout75
Runabout75
tbucketjack
Are you saying the just compressor is gone or everything from under the hood and dash?
Runabout75
Anyone have any advice on adding new air conditioning to a 1973 Runabout? It had air at one time but was gone when I bought it. Best advice?
Runabout75
