Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 01/10/2022 03:41 pm
Date: 07/17/2018 09:22 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Date: 03/17/2019 10:15 pm
Date: 10/24/2018 07:41 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 04/08/2018 05:47 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
  • Online today: 535
  • Guests: 474
  • Total: 474
oil pump pickup tube gasket not available?
Started by pintoguy76, June 13, 2013, 11:58:47 AM
289Wagon
 The Ford number is D4FZ6626A.  They are available at several dealers in old stock parts. Heck, Green Sales shows 62 in stock.
tbucketjack
Getting on here late, The Ford Dealer may say its obsolete but can do a nationwide parts search. I needed a "C" clip for a front hub bearing for a 1996 Mercury Villager and none were available in AZ but a dealer in TX had 6.
I got one with a new old pump. You might want to put a new pump in if you do not know how old pump is but do not get a high volume one.
I have not used anything in years, surfaces are machined well. Although you could do as Timmay suggested.   Fred   :)
I just used hi temp silicone on mine just make sure ya don't glob it on so it doesn't go inside the tube.
If it's just a plain gasket should be able to make one?..
Not yet. I read online somewhere tho that ford discontinued them a long time ago..
tbucketjack
By any chance did you try your local Ford Dealer?
Absolutely no one has a listing for a gasket that goes between the oil pump and the pickup tube for a 2.3.  Not oreillys, not autozone, not rockauto. I need one for my engine to put the pinto pickup tube on my mustang engine. The only way to get it so far is to buy a new oil pump or buy a complete gasket set - which i dont need. Can I just use black silicon sealer or what?
