Date: 05/28/2017 03:20 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
KYB shocks
Date: 02/08/2017 07:09 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 03/21/2017 07:47 pm
Date: 09/12/2018 04:07 pm
Pinto drive train
Date: 06/29/2018 08:32 am
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 533
  • Guests: 318
  • Total: 318
What type of brake fluid?
Started by oldcarpierre, June 10, 2013, 08:21:44 PM
oldcarpierre
Guys, thank you for your help.
I will pull some of the old fluid and see of it is clean.  Depending on condition, top up with DOT3 or replace.
You can mix the 2 but if you start diluting Dot 4 (expensive) with Dot 3 (cheap) you defeat the purpose of the expensive fluid which is a 450 degree boiling point. It's the silicone fluids that don't mix with conventional fluid. Silicone wont absorb water so it will force the water to the calipers & wheel cylinders & corrode & gum things up.
Don't waste your time with silicone fluid.
OhSix9
the above is right.  just don't mix it.  sounds like somebody used dot 4 on your last unit.  mixing dot 3 and 4 typically makes a bunch of goo which will require that you flush and rebuild / replace everything along the way.  that said if you are starting fresh go dot 4.
Virgil to Sid
Any Dot 3 works fine whether it's called synthetic or not. There is no difference. If you did a lot of performance driving then Dot 4 is preferable with it's higher boiling point. If you flush your lines with fresh Dot 3 you will raise the boiling point of your fluid by over 100 degrees. It's a good reason to flush yearly.
sedandelivery
My one Pinto had a sticker on the master cylinder stating use DOT 3 brake fluid only. I have 1980's they are all the same I think.
If you don't know what's in it now and it don't look clean, best thing to do is flush the system and put fresh DOT3 in, that way you'll know what you have and have piece of mind that the brakes will work, that's not something you want to cut corners on..
As per the 1976 Ford Pinto owners manual use the ESA-M6C25-a of which should be DOT 3. It should be marked on the bottle IE if it says Ford spec that's what you use. Note for automatic transmission fluid use the Ford spec plus the year IE for use in Pre 1985 or so cars. Get an owners manual and use bing.com to get search info.
dennisofaz
Hi Pierre,
I have always used DOT3 brake fluid on my Pintos.
Dennis
oldcarpierre
Guys,
Back in 1982, a mechanic put the wrong type of brake fluid in my 1980 Cordoba.  Everything seized up: master cylinder, metering valve, brake cylinders.  Served me well for driving a Mopar.
Fast forward to today.  I need to top up the brake fluid on my `74; a simple machine with no power brakes.
The guys at my local Ford dealer do not know for sure.  They think DOT 3, but not sure.
What should I use?
Thanks.
