77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 03/13/2021 12:57 pm
Date: 02/03/2018 11:28 am
v8 springs
Date: 05/07/2017 04:46 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Interior Parts
Date: 08/07/2017 03:59 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
  • Online today: 529
  • Guests: 355
  • Total: 355
rear end identification...
Started by Cookieboystoys, June 09, 2013, 06:26:31 AM
While the post isn't 8" specific, the title is enticing. So I'll throw this out for anyone interested. I believe only the 3.00, 3.40 and 3.55 were available for the 8" rearend.  Some of the ratios seem to cross over between the 6-3/4" and the 8" (3.40 seemingly one of them).
  Every time I go to Pick A Part (monthly - Sun Valley, CA) I check the 8" rears.  The majority sadly have the center sections already pulled.  There is one guy who at a minimum goes through weekly and pulls them all. Virtually all are 3.00 and a few 3.55.  When I did my turbo swap I opted for the 3.00 thinking the Pinto was lighter than the Turbo Coupe and the 13" or 14" tires would work well. Ahhh..., not so much.
Ideally I think 3.25 would be best with shorter 13"-14" tires.  But that ratio is limited to only a few older Fords. Otherwise it is the price of aftermarket gears and setup. So my quest is now for 3.40 as a compromise.  If your running 16" tires you might get away with 3.55.  Please note these ratios are referenced to daily driving.
Tom
Quote from: Cookieboystoys on June 09, 2013, 06:26:31 AM
door plate says 7
Opps! My Bad.... code is an 8 not 7 which at 2.78 sounds right for a 4 spd  79 pinto/bobcat, autos had 3.08 and I have one of thoes too.
? 3.40 ? I didn't think they offered that except for 1973 in a pinto? maybe I can jack it up and read the tag.
289Wagon
 I can't say for sure on a '79 but I have this for '73-'78. NOTE!! code 7 for '71-'72 is different - 3.18 non-locking.
anybody know the door data plate codes for rear ends? door plate says 7
1979 Bobcat
