1979 pinto
Date: 04/19/2018 02:02 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 09/12/2018 12:33 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 10/31/2018 12:04 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
  • Online today: 563
  • Guests: 228
  • Total: 228
74 Wagon Wiring Diagrams
Started by pintoguy76, June 05, 2013, 12:05:39 PM
Go to www.rothfam.com/svo/3g etc. . Many places have the info for the swap. I'm getting ready to do the swap myself. I'm using a 130 3g from a mid 1990's Taurus and a pulley from oldfuelinjection.com. I'm keeping the v belt system because two belts are better than one if it's running the alternator and water pump. One belt on the serpentine system seems to be a high chance of failure but that might be just me. Plus I do not feel like changing any thing else. The belt I need might be a little smaller but not too much.
Getting ready to do a fuel injection swap on my 74 wagon. Currently has points type ignition and externally regulated alternator. I need to know how to rewire the car for an internally regulated alternator and where to connect the EFI harness to the car at.
Pin 1 (keep alive power) will go to the always hot side of the starter solenoid, but i'm not sure where to get the 12v in run and 12v in run/crank at.
Also for the alternator wiring, the regulator has 5 wires coming out of it, one to a condenser, two to the alternator and the other two I dont know where they go? One i assume is for the charging light but I dont know about the other one. Those two will need to be done away with or hooked up, but i need to know what they do and where they go to be able to do that.
Please help if you can!!
Thanks!
