Wheel cap
Date: 04/25/2022 11:21 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 08/05/2018 01:58 pm
Crane Cam
Date: 02/26/2018 07:50 am
front end parts
Date: 03/30/2018 12:48 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
  • Online today: 489
  • Guests: 173
  • Total: 173
2.0 stroker to 2.3 swap
Started by ddewey78, May 31, 2013, 11:18:29 PM
fast64ranchero
If it has a crank swap from a 2.3 then it is a Ranger 2.0 not a EAO (early 3 cam bearing German 2.0L) a 2.3 crank will not go into a early 1970-1974 2.0L
72 old V-8 parts Pinto
73 pinto, the nice one...
71hotrodpinto
Yep sorry to say that nothing will interchange for those 2 engines. The 2.0 was a 71-74 German engine and the 2.3 design that went till '98, was a Brazilian engine. They only look similar.
The 2.3 is a great engine with a lot of potential and parts backing from esslinger engineering . Hi po parts are not cheap however, basic matinence parts are.
If you swap the 2.3 it will fit however its not a total bolt in. The 2.3 is great for a rail. Good luck!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
The Ranger 2.0 is basically a 2.3 so my guess is that's the swap. The German 2.0 is a whole different animal.
ddewey78
   Ok guys, im a newb to pintos, well honestly to fords in general. I have learned a ton so far from you guys already.
   So I bought a sand rail with a 2.0 in it. I then swapped it for a "stroker motor" so i was told. Apparently a 2.3 crank was stuffed into a 2.0, any one ever hear of this? Any ways i have a complete mustang with a fuel injected 2.3. What is required for the swap, do i need a custom computer? would it be easier to put the offenhauser and holley from the 2.0 on it? would it even fit? I also have a quad mukini set up.  What parts would swap? header, oil pan, intake, valve cover? Is the bellhousing pattern the same?
  Thanks in advance, you folks are a wealth of knowledge!!
