1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 03/27/2017 10:07 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 10/04/2019 08:43 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 535
  • Guests: 506
  • Total: 506
Need help with alternator......
Started by Glitch666, May 10, 2013, 12:39:29 AM
1oldtimer
Ford ran an external voltage reg up into the 80's and then a serp belt. On my 390 and the pinto motor I'm running a GM 10si, almost a bolt in.
'72 2.0 in a '28 Ford.
I have 2 Ford 100 amp 1-wires. One is a black Summit version & the other is a polished Tuff Stuff.
Glitch666
I just finished the 3 wire swap. It's internally regulated. Also my alternator light still works. It's also 130 amps. I had to notch my lower alternator bracket so it would fit but that was easy with my grinder.  The gm 1 wires are cool but there's pros and cons with them.
Why not just swap in a 1-wire alternator & be done with it. I have one for all 3 of my Pintos. You get higher amperage, steady output & no regulator to fail.
Glitch666
Ok so I have replaced the alternator and regulator numerous times, but in the end I always have voltage issues. I wanna just do the 3 wire swap and was wondering what ford cars came with the 3 wire that will fit on my 2.3. Any body know?
EDIT: If anybody needs info on this check here, this answered all my questions. http://fullsizebronco.com/forum/showthread.php?t=55169
