Squire trim
Date: 03/28/2018 10:11 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 08/17/2022 06:27 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 10/10/2019 09:42 pm
Date: 08/03/2018 09:19 am
Date: 07/30/2020 11:45 am
Date: 08/02/2019 04:18 pm
  • Online today: 536
  • Guests: 423
  • Total: 423
71 sedan rear end off center
Started by ZX10RDER, May 02, 2013, 11:44:39 PM
accident damage sometime in the past? you should get the same measurements (or very close to it) on both sides.
ZX10RDER
Putting wide wheels on the back of my 71 sedan and found that the rear end is offset towards the driver side . Measured from backing plate to springs and axle is centered on the springs .it appears that spring mounts are offset on the body .with a bare wheel bolted to the axle and a straight edge across the wheel. measuring to the outer finder lip it is 1 inch offset to the driver side .has anyone had this problem if so any help will b greatly appreciated
