2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 10/25/2019 03:30 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 11/11/2019 03:38 pm
  • Online today: 529
  • Guests: 480
  • Total: 480
1st time pulling apart 2.0, a couple questions.
Started by Sir Thomas Crapper, April 29, 2013, 07:52:30 AM
I'll second that unleaded fuel statement. When driving a '74 2.3 the mileage between yanking head got less and less, about 35000 on low lead, and then about the time they announced ALL lead was gone that mileage had dropped to like 15000 miles. Doing a head ever year then, what a crock. You shoulda seen the exhaust valves, they dropped like 1/16" plus in that year. Bad enough the tips got taller to use up lifter internal length then valve starts hanging open to burn.
jeremysdad
I'll have to try to find the receipt. That's been many nights of sleep/adult beverages/2 new phones ago. lol :)
Scott Hamilton
jeremysdad
I'm not a betting man. You burned a valve. :) Specifically, an exhaust valve. I have my #3 in a baggie, and it looks like a 'D' instead of an 'o'. lol
I still will hope that you didn't...but when they took the lead out of gas and reduced the octane ratings, bad things happened that the manufacturers couldn't have seen coming. Valves burned...and American machine shops got rich. :)
I predict another 2.0 head rebuild. I got lucky and found a local (Nashville, TN) shop that's been racing 2.0's since the beginning...magic happened that I'm not 100% sure I paid for (Son: 'He didn't pay for that intake port weld/port work.' Father: Can I do anything less for a Pinto head??? lol)...but I have a smoking quick wagon, when I want it to be. :)
jeremysdad
The head bolts are a 'triple square' head, common on German automobiles. It looks like a torx, but is not a torx, nor is it an internal 12-pt. The edges are truly square, so attempting to use anything but the appropriate bit will cause you issues. I bought mine from Amazon, and believe they were 12mm (was glad I got a set, cause everything I found said they were 10mm, but they most definitely were not.) Try to remove as much oil out of the heads of the bolts as you can before you start, otherwise the hydraulic pressure created when you insert the bit may not allow a full 'bite' of the bit, and could lead to a stripped head. :)
This is the set I bought...and have since misplaced the 12mm. O.o lol http://www.amazon.com/GearWrench-80572-8-Inch-2-Inch-Metric/dp/B000NIAIJC/ref=sr_1_7?s=automotive&ie=UTF8&qid=1367246079&sr=1-7&keywords=triple+square+socket
I used a Fel-Pro gasket set and have had no issues. One thing I discovered (the second time I had the head off) was that there is a small (1/4" or so) vertical passage between the head and the block, directly under the thermostat housing's location. Mine was clogged with crud. After cleaning it out, my choke kicks off more quickly. Must be the bypass or something. Also, there are no locating dowels for the head gasket. I carefully set my head down and had no issues, others have used old head bolts and made locating 'studs' out of them by welding extensions to the top. :)
Here's hoping it's as simple as a head gasket, and that you require no machine work or other parts. :) Good luck!
Sir Thomas Crapper
Have a bad leakdown # on # 3 cylinder. (70%)  Adding oil, no help.  We're going to pull the head.
This is for our 24 Hours of Lemons car.
We've done a 2.3 before.  Same basic stuff?  Looks pretty similar.
I'm hoping it's just the head gasket.  Is a Fel pro gasket a good replacement?  Part #?
Anything else to look out for while the heads off?
1-3-4-2 firing order?
