Date: 01/23/2017 07:41 am
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 05/21/2019 11:50 am
Date: 07/08/2017 08:25 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
  • Online today: 600
  • Guests: 563
  • Total: 563
Will these wheels fit a 73 wagon?
Started by 72Wagon, April 18, 2013, 08:06:21 PM
Quote from: 72Wagon on April 20, 2013, 08:00:39 PM
Its a shame they did this to these wheels, they are good looking wheels. Are there any other good looking factory wheels that will fit my 73 that dont require $400 tires. Pics would be nice if you have any.
The fox body mustang 10 hole wheels should fit if you get the right tire size for the front.  They are 15" wheels.
http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?LugCount=4&StudSpreadInch=4.25&StudSpreadMM
http://www.summitracing.com/search/department/wheels-tires/part-type/wheels/wheel-bolt-pattern/4-x-4-1-4-in/brand/wheel-vintiques
http://www.summitracing.com/search/department/wheels-tires/part-type/wheels/wheel-bolt-pattern/4-x-4-1-4-in/brand/circle-racing
there are a ton of wheels with the proper bolt pattern. be sure to triple check the back spacing/offset before you buy.
many foreign cars use the 4x4.25 (4x108mm) wheels.  i had a set of multi-spoked 14x7's off an Audi that were a bolt on for an '80 Fairmont (302 out of an HO Mustang under the hood) that i had. would have bolted right on a Pinto too.
there are many to choose from.
72Wagon
1972 Wagon
Mike Modified
Top of the line tire technology when introduced.  Not a Ford idea, but from Michelin, used by a number of car companies.
http://en.wikipedia.org/wiki/Michelin_TRX
They take a 14 1/2" tire. I'm not sure what idiot thought that was a great idea at Ford but they did it.
Reddog
Yep, I agree. I had a set too, weird metric tires, very expensive. I sold them for $100
Everyday is a gift! Live it to the fullest with no regrets!
72Wagon
Thanks, you saved me a lot of trouble and money. Will keep looking.
1972 Wagon
I have seen them on early pinto's before but I suggest finding another wheel as those TRX rims take special tires that are $434 a piece.  It is an odd metric wheel that equates to something like 15.3" in diameter.  Don't quote me on the size but it is odd. The only place to get the tires are from Coker tire.
72Wagon
Found these on CL, will they fit on my 73 wagon ? They are 15 inch mustang and he is asking $125. If they will fit what size tires will work without spacers and interference with fenders / suspension?
Thanks
1972 Wagon
