Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Date: 04/06/2017 12:13 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 01/10/2022 03:41 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
  • Online today: 583
  • Guests: 471
  • Total: 471
Need proceedures in removing/replacing starter in 76 wagon w/4cyl.
Started by mrlightrail, April 12, 2013, 04:24:41 PM
Some racks only have 2 some had 3 if yours only has two the rack should be able to be moved...Unless it's still hooked up to the steering coupler ? Some say you do not have to disconnect the coupler (I have) in order to drop the rack. Note it still should be hooked up to the tie rods etc unless your replacing the rack...
82expghost
I cant find that third bolt, I'm going crazy! Where is it? Am I missing parts?
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
mrlightrail, I tried to tell  you....If you have any questions I'll try to give you the correct answers...One thing to correct is that the steering wheel will not move if it's locked but the wheels can when you disconnect the coupler. It's not a big deal if you ensure they are straight before you let the car on the ground....Again no big deal if they move push one side to square them up before you lower the car....If the steering coupler is not where you need it move the wheels not the steering wheel...Do not unlock the steering wheel until every thing is tight.....And nothing else should move...If you did not disconnect the coupler no problem, I had to when I removed the starter on my Pinto and every thing lined back up...No weird wear etc on the tires or steering problems....
mrlightrail
You got that right on the messy part. Already took two pieces of crud in the eye. Always falls at the moment I take my safety glasses off for a better look.
The bolts to the steering rack are easy and if you lock the steering wheel (take the key out) it will not move. Unless the lock on the steering wheel is broken....I've done the work and it's not hard just messy. You might be able to remove the RH motor mount and jack it up but be careful...Sounds like the bendex drive is shot...Check as best you can the condition of the ring gear on the flywheel , some times they get worn...The transmission should have a dust cover to allow you to check....
mrlightrail
Issue was that the starter would freewheel after maybe two engine revs. The mechanism that pushed the gear out to engage the flywheel was dying.
Cable from solenoid to starter getting old, will need to replace, but cannot now. No car...no trips to parts house.
I heard that you could also remove the RH motor mount connection, put a block of wood underneath the oil pan, and jack the engine to get the starter out. I REALLY DO NOT want to mess with ANY part of the steering mechanism.
Your steering rack has 3 bolts not two if it's a 1976 Manual rack (Do not know about power steering). #1 jack the car up (if you have not done so.) Clean the cross member on both sides  so you can find the nuts and bolts also to keep crud from you eyes (Yes I've been there and got crud in my eyes) #2 remove the steering rack nut's and bolts (Yes it's a large nut and a long cross bolt and there are three of them).#3 drop the rack( you might have to remove the cross bolt the attaches to the rag joint). And that's it. Oh it might be a good idea to change your bushings on the rack (mine where shot). Are you sure it's not the starter solenoid ? Check to make sure. Also have you checked the small wire elbow on the solenoid they fail allot, IE they do not connect to the stud on the soleniod.(I cut mine off and put a treaded wire loop connector).How good is the cable going to the starter and solenoid ? It should be changed as long as your in there...They do get old and fail. For new cable you might have to grind down the sides on the end that  goes to the starter in order to get the cable to fit..It's some times too wide.
82expghost
Take the 2 nuts holding the rack off, let steering rack dangle, starter slips past through front over rack
mrlightrail
Pretty much as the subject. Need the info asap, as I've already pulled the starter, but cannot remove it from the engine bay.
