1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 12/15/2018 02:21 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 03/05/2017 03:27 pm
Date: 12/09/2018 06:59 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 02/28/2024 02:07 pm
Date: 10/05/2017 02:26 pm
  • Online today: 403
  • Guests: 220
  • Total: 220
Over amping issue
Started by Shane198three, March 16, 2013, 06:09:27 PM
An unregulated alternator can push 17 volts. Try a regulator & it should fix it.
ToniJ1960
 Well it is the job of the voltage regulator to regulate the voltage. I have heard of cars overcharging before but Im not sure what the causes are that can do it.
But, if youre looking at a 1 volt difference or less I wouldnt count on a dwell instrument that has a voltage scale. At least use a decent vom if not a digital meter to check it. One volt out of fifteen volts is only about six percent. If its over 15 I would wonder though, over 16 I would be surprised if you arent losing instrument bulbs or other bulbs.
Shane198three
Oh, I know it, I have replaced a few, but none from an over amping issue, that is why I am asking if anyone knows if this might be the cause. I have never come across this issue before.
wbacon8780
Voltage Regulators are not expensive. Just picked one up myself at Advance auto parts...20 bucks.
Shane198three
I checked it out with a dwelltack a week or so ago. Just now getting to the forums to ask.
wbacon8780
That is a little high usually it's about 15.5 volts. I would be thinking Voltage regulator. I would check it with DVOM first.
Shane198three
Hey guys,
This question is about my 1974 Mustang 2 Mach 1, but it is nearly the same car, at least in my humble opinion. ;-)
So I start the car up, without any electronics running, and I run at 13-14 volts. But as soon as I step on the brakes or turn on the lights, and I am sure use the wipers or turn on the heater, the voltage jumps up to 16+ volts.
POSSIBLE ISSUES:
Voltage regulator...
Alternator...
A short in the wiring...
Please give me some ideas and replacement plans...
Thanks,
Shane
