Date: 09/12/2018 12:33 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 03/25/2019 09:02 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
  • Online today: 403
  • Guests: 251
  • Total: 251
Off sets and wheel width
Started by johnbigman2011, February 09, 2013, 07:17:43 PM
OhSix9
sn 95  95-04 mustang offset will work.  and since your gonna ask. if you are using a t5 get an awd aerostar aluminum driveshaft.   Oh and the tunnel will need a little "massage" where the rear ujoint is. with the slight pumpkin offset it will rub when you launch hard and squat the rear
Virgil to Sid
johnbigman2011
Explorer.. I was just trying to expidite buying of wheels. I sorta figured that it would need to be installed before final off set could be determined.
It's a bummer when you only have two weeks off.
Thanks,
OhSix9
OhSix9
need more info man.  8.8 out of what?
275's on about an 8 inch rim  seems to be about the limit for tire and rim width regardless of od.  offset is simply a matter of which diff you are using as that affects the wheel mounting surface to wheel well edge relationship and can only be figured  once we know the mounting surface to mounting surface width of your diff.
Virgil to Sid
From_Jonah
I have 8 inch wide wheels on my wagon and I had to use 1.5 inch spacers to get good clearance.
johnbigman2011
I'm installing an 8.8 rear end in my 72 and I wondering what is the widest tire/rim that can be used and also what offset? Needing to buy some tires/rims.
