Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Crane Cam
Date: 02/26/2018 07:50 am
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 05/21/2019 11:50 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 02/03/2018 11:28 am
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Online today: 452
  • Guests: 294
  • Total: 294
2.8 leaking front seal
Started by 78_starsky, February 03, 2013, 01:42:48 PM
78_starsky
was able to get the speedi sleeve and a new seal onto the car this afternoon....  happy to report back that after about 25 minutes of different RPM's she didn't leak a drop.
thanks Dennis for the reply.  that worked.
cheers
78_starsky
thanks dennis!   this is what i was told on a different site that i posted this same prob on.
I have a new sleeve and seal on order for pick up tomorrow.   glad to hear it is an easy fix!!!  i was oh crap now what....
will post an update if this fixes it.
cheers
dennisofaz
hi 78 starsky,
I would look at the harmonic balancer's shaft, where the seal rides, and look for a grove that is made by the seal riding on it.  There are sleeves that you can buy at the parts store to give the seal a good surface to ride on.
Dennis
78_starsky
hey all
This car still hasn't been moved under its own power.... getting close though. tackling the front seal problem.  can anyone help on this one?
Prob is that the front seal leaks when the engine is running on low idle,  roughly 7-800 rpm.  above that no issues with leakage. do these seals get old and dry out even if never installed before?  I am going to take the harmonic back off today and pull the seal out again and replace it to see if this corrects the prob.
If it does GREAT,  if not what can cause this to happen?  head scratcher on why low RPM leaks.  is there a newer style seal that I should be asking for>?
cheers  thanks
here is a build thread for the car if anyone wants more info.
http://www.fordpinto.com/your-project/project-%2778starsky%27/
