Pinto Watch
Date: 06/22/2019 07:12 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 07/03/2025 04:35 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Online today: 427
  • Guests: 371
  • Total: 371
I need parts for my '75....will a '77 work?
Started by James Meter, January 27, 2013, 05:21:59 PM
OhSix9
The inserts are not reusable.   they are about 25 cents a piece at the local bolt supply.  the inserts have a crush on them and expand to lock into place.  Usually you have a tool to expand them but it can be done using a bolt, washer and a nut.  the fenders and rad support are the exact same so everything will swap from one to the other as a complete group(fender extensions grill  etc, , I think you need the hood latch and support. ) if you want the slanted headlight buckets you will need the grill too.   the unibody is unchanged from 74 on so everything will swap over on the inside.
Virgil to Sid
The inserts are similar to the ones used to mount the side mirrors on the doors.  Not sure if you can reuse them as they will be hard to get out.
James Meter
These threaded inserts, is there another place on the car that'd have them? I'm trying for el-cheapo here.
Everything should swap over.  You will need some threaded inserts for the roof rack.
James Meter
Here before too long (a month or two tops) I'll be getting a '77 Pony Wagon (has a horse on the steering wheel..has holes in its spokes.)  to help benefit my green '75. now comes the questions!
WILL THESE PARTS FIT?
1. I want to swap out basically the whole green interior (everything but the column and auctual dash) in favour of black parts. Seats, drilled steeringwheel, 8-track, dash pad..etc..etc)
2. The roof rack. From what I understand, it bolts straight into the sheetmetal (Nothing used between the headliner/roof.)
3. I'd like to use the full front clip (slanted headlight buckets still has circular bulbs) on my '75 with my stock headlight boxes (flat, hexagon shaped). The grille won't swich over, but will everything else? (Hood, passenger fender, hood hinges..mabte the bumper shocks too?)
4. Driver side inside door release (the rotating part)
Side Note:
I really don't want to see the wagon go to the scrapper-private message me if you could use any of the left over parts and want to come get 'em.
I will not ship..might meet halfway?
No Title For the Wagon
