KYB shocks
Date: 02/08/2017 07:09 pm
Date: 06/19/2018 03:58 pm
Date: 09/20/2018 11:01 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 07/30/2018 04:32 pm
Date: 03/25/2019 09:02 pm
Date: 04/24/2018 11:45 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
  • Online today: 2,622
  • Guests: 2582
  • Total: 2582
Mallory HEI Distributor
Started by PJO Pinto, January 26, 2013, 07:22:42 PM
I do not think so, but try turboford or some of the U.K. sites for older cars. If you need parts for the 2.0 EAO try Burtonpower.com they have damn near everything for the EAO and the good old 4 speed transmission....Even some T-5 stuff (for the Ford Sierra RS500 etc).
PJO Pinto
Thanks for the replies gents!
I am building a 2.0 EAO/Pinto/Not-Lima at the moment. Will the crank pulley from a 2.3 fit on mine?
im using a modified dizzy on a 2.3 with crank trigger. using the dizzy as a cam sync it had 4 vanes on it.... cut 3 vanes off leaving one as the cylinder id sensor..
Try to use the DIS pulley and sensor from a 8 plug Ford Ranger, after all it's a 2.3 and a Ford part if I remember right the sensor was near the crank pulley with the brackets.....Then the only thing the distributor gear(timing belt gear) runs is the oil pump.Esslinger has some parts for the swap.
PJO Pinto
Thanks for the reply! I am going to be running a standalone ECU.
For now I have dropped the distributor completely from the plans. Going to run a DIS (distributorless ignition system) by attaching a 60-2 crank trigger wheel to my crank pulley. Now just trying to figure out how to turn my old distributor into a cam position sensor.
Are you using a standalone or swapping a stock ECU system.....If your just adding a turbo to a blow-thru carb system the petronix should work fine....
PJO Pinto
http://www.amazon.com/Mallory-4558201-Breakerless-Electronic-Distributor/dp/B000FVU7GG/ref=dp_return_2?ie=UTF8&n=15684181&s=automotive
http://www.autozone.com/autozone/parts/Mallory-Distributor-Performance/1972-Ford-Pinto/_/N-ipo5tZ93yu9?itemIdentifier=711714_529393_0_
Hey guys! Looking into the future of my ignition options. I am currently assembling parts for a turbo 2.0 (after a bit more research and decisions I will post my build here).
Currently I have the standard bosch distributor with the petronix ignition in it. I will probably run this initially, but have been interested in this Mallory unit.
Does anyone have any experience with these? Autozone says it is an HEI distributor, which I know some ecu's can even control the timing on. Looking for my best option to have proper timing. Thanks in advance.
