Date: 12/15/2018 02:21 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 08/08/2017 01:44 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 01/23/2017 07:41 am
  • Online today: 2,612
  • Guests: 2478
  • Total: 2478
Turbo rebuild
Started by johnbigman2011, January 17, 2013, 05:52:44 PM
johnbigman2011
Thanks for that Pinturbo75.
Quote from: Pinturbo75 on January 17, 2013, 08:43:52 PM
ive had charlie at evergreen turbo do mine.... nice work at a good price... hes also a 2.3 guy....
Post it if that's OK. I may need him too if my T3 needs freshening.
johnbigman2011
Could you send me his contact info in a PM.
Thanks
fast64ranchero
Isn't the shaft brocken you yours? if so, it'll need to go to Garrett, It'll be pricey, and I think it needs a exh housing with a waste gate, might be cheaper to buy new right from Garrett with the correct seals...
72 old V-8 parts Pinto
73 pinto, the nice one...
cabecho
that is a risk you can have even if you have some one do it for you..
Aerodynamics is for those who can't build engines
If ford pintos are not fast then why chevy's have to use there parts to make them fast?
johnbigman2011
I've been reading all kinds of info about rebuilding and buying the kits. What concerns me is balencing everything and the big fear of what happens when I do it wrong and send the parts throug the head.
OhSix9
If the wheels are in good shape just order the bushings, thrust bearing and seals. It is mostly a simple hand tools job.  Make sure to clock the compressor wheel and scribe the nut to put it all back in the same relative position and bob's yer uncle. google it, the parts are cheap and there are how to videos. I would recommend you make sure the parts are brand name stuff as the only word of caution.
OhSix'
Virgil to Sid
cabecho
john we can actually send it to garret and have them rebuild it.
even if is not build by them they will rebuild it.
johnbigman2011
Has anyone had a turbo rebuilt before? If so, who would you recommend?
