Automatic transmission
Date: 02/13/2021 02:52 pm
Wheel cap
Date: 04/25/2022 11:21 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
72 pinto
Date: 06/23/2016 12:40 pm
Date: 11/14/2019 04:02 am
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 01/24/2021 07:54 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
  • Online today: 553
  • Guests: 238
  • Total: 238
'77 2.8 V6 oil leak from filter adapter
Started by totljeep, January 14, 2013, 05:04:04 PM
flash041
It takes a special o-ring, which I could not find either. I found the closest size o-ring and put it in. It leaked a bit so I took it apart again and coated the o-ring with heavy gasket sealant.Seems to be working ok now.
Or you can do it by cross etching with sand paper and do a whole seal with orange hi temp silicone and let cure 24 hours and you are good to go !  Fred   :D
jeremysdad
You can always buy some gasket material (available in sheets at the major auto parts houses) and cut your own. Been there, done that,but not with the 2.8. The concept is the same, though. Hope that helps.
totljeep
I called 3 parts stores and cannot find a gasket.. Anyone know where to find it??
Thanx,
David
FIX MY PINTO ELSE I'LL DRIVE IT LIKE IT IS!
