Date: 04/13/2018 11:30 am
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 11/12/2020 08:28 pm
Date: 12/09/2018 06:59 am
Date: 07/17/2018 09:49 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Bumpers
Date: 07/06/2018 04:47 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Date: 10/10/2019 09:42 pm
  • Online today: 210
  • Guests: 193
  • Total: 193
window gasket
Started by sedandelivery, January 12, 2013, 02:57:49 PM
sedandelivery
Thanks, guys for the info. I will order a set.
78txpony
Convertible Top Specialists have them also.  I need to get a set myself.
http://www.topsdown.com/1971-1980-Ford-Pinto-window-sweep-set--p1023.html
I did get their door weatherstrip and window channels and was happy with them.
You MIGHT be able to pop the sweeps out with the window all the way down.  If not you will need to remove the door panel and lower the window-down-stop so you can lower the window another inch or so.  That should give you all the clearance you need.
-Rob Young
1997 H-D Sportster
Ebay. I got a pair of aftermarket units a few years back & they look & function like the original ones, with the exception that they don't look all worn out.  They are held on by metal clips & a small putty knife in between the moulding & door should pop them out.
http://www.ebay.com/itm/1971-1980-Ford-Pinto-Mercury-Bobcat-door-window-sweep-seals-belt-line-molding-/200796910900?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2ec06db534&vxp=mtr
sedandelivery
On each door there is a rubber piece that attatches to the door and contacts the window on the outside as it goes up and down I guess to keep water from going into the door. What is that called and where can I get a pair?  It looks like it is attached with little rubber clips. How can it be changed, ie does the window have to come out of the door? Thanks a lot, folks for any info you might have. My other rubber gaskets are in really good shape.
