72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 03/25/2019 09:02 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 08/30/2018 12:59 am
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 08/05/2018 01:58 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
78 windshield trim
Date: 02/01/2020 08:46 am
  • Online today: 586
  • Guests: 255
  • Total: 255
Early radiator (71-73) needed
Started by fast64ranchero, January 11, 2013, 10:25:44 AM
I adapted one from an early 90's Dodge Dakota. It has the hoses on the correct sides & they are the correct sizes.
OhSix9
I am runnin a '94 explorer rad from the 4.0l   .   Lots of volume, aluminum and cheap.  only needed a couple of saddles made for the bottom.  top is passenger  side bottom is on drivers.  should fit the hole and leave room for piping
Virgil to Sid
johnbigman2011
Walt, miss read the posting.. I only have a stock one I see what your looking into.
johnbigman2011
Walt, I have one in the garage at the house that your welcome too.
fast64ranchero
Fred, Is the 74 Mustang radiator the same as a 74 and up Pinto radiator? I looked at the later Pinto radiators, I'd have to swap the intlet and outlets for the 2.0L, or use my tanks. Do they have the same mounting holes?
72 old V-8 parts Pinto
73 pinto, the nice one...
I am running a 74 Mustang in my 73 that is larger then stock due to hi heat here.  Fred   :)
fast64ranchero
I can find a "new" stock radiator for my 72, I know I can have a new core put in my old one, but I'd like to know what other radiators you guys have used, that are close to stock size.
I can't go much wider than stock, as I need to keep room for the intercooler piping, I can have a custom built aluminum made for $650 ouch! :o
