nos core support
Date: 01/03/2020 09:39 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 10/24/2018 07:35 am
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 01/24/2021 07:54 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
  • Online today: 481
  • Guests: 149
  • Total: 149
charging help on a 71
Started by oldschool787, January 08, 2013, 04:51:33 PM
oldschool787
i did have a problem before my motor went a long time ago with the black T thing the yellow and green wire broke off and i connected the best i could and i worked for at least a year does that black thing have to be there or can i get rid of it and redo the wiring and connectors
I might own one FORD but, I own a Chevy and a trailer.
72pair's makes a good point. While replacing my alternator on my own beloved '71 (1.6 and 4 speed) one of the wires on that little spider cluster that attaches to the alternator broke- just broke. The wires and insulation snapped as if it was just brittle old plastic. That was when I knew panic time! I was able to fix it with sone creative carving and a splice, but one day recently the splice came apart and the Alternator light came on. Again I was able to fix it... but I'm running out of wire.  :o   The funny thing is this keeps happening right before a Pinto event (a car show and Barth's Xmas party respectively).
72pair
check the plug in connector on the alternator harness if the wiring is original.
oldschool787
new and tight just replaced it when i rebuilt the motor last month also went through checking the grounds and wire connections
ToniJ1960
oldschool787
so i took my pinto for a drive today ran great until i got like 3 miles from my house and the alternator light came on and the amp gauge started to jump 12 to 14 back and forth i made it home thought it might be the voltage regulator so i changed it didn't help it can set at idle and charge at 14 or so but when you go down the road the gauge jumps around and the light comes on as anyone had this problem before I'm thinking i might replace the alternator next but first i wanted to see any cheaper ways it a 71 pinto with the 2.0 a/c 4sp all stock
